Old 04-25-2007, 10:53 AM
OrIoN's Avatar
OrIoN OrIoN is offline
Trans Cooler Upgrade
So are most of the cooler upgrades found (such as the svxmotorsport) direct swaps from the OE unit. Same fittings and mount - location ???
OrIoN's harem is Pleiades
'96 SVX LSi AWD
'93 Audi S4 20v Turbo 5cyl Silver/ Platnium
Euro converted, EO Sports Suspension, RoH Reflex, Denon ICE
Euro Converted, ABT/ Bilstein, MTM stage 3+ (340hp), ABT exhaust, Euro S6+ brakes, Gloss Black trim, Alpine/ ADS ICE
'93 Audi S4 20v Turbo 5cyl Black/ Ecru
MTM Stage II, H&R 29921/ Koni adj., RS4 wheels, Boxster S Brembos on 2-piece Colemans, Old Skool Lanzar ICE
Old 04-25-2007, 10:59 AM
jman050's Avatar
jman050 jman050 is offline
Its a Classic!
no, the stock transmission cooler is inside the radiator. you can either bypass it with an aftermarked cooler or run both. Either way you have to find a place to mount it and fab something up on your own.
[SIGPIC][/SIGPIC]
Old 04-25-2007, 11:03 AM
OrIoN's Avatar
Thanks... so whats the common solution? where are people putting the new cooler?
'96 SVX LSi AWD
Old 04-25-2007, 11:26 AM
davew833 davew833 is offline
most aftermarket coolers are thin enough to fit between the radiator and condenser-- that's where I put mine. Some have mounted theirs to the lower inner fender with an electric fan to draw air through.
davew833@yahoo.com
Former 6-time SVX owner
Old 04-25-2007, 01:43 PM
Delfonso Delfonso is offline
Tranny cooler
Check the How-to-Documents under transmission. I've got the B&M supercooler. It's to thick to be mounted vertically, but supposedly there's better airflow when you mount it as described in the How-to-Doc.
San Ill Delfonso
94 Barcelona Red FWD, ECUtune stage 1 v 5, Small Car shift kit, Raceconcept rotors, Akebono Pads, Rebuilt transmission by SR Hydramatic, JDM hood emblem, 225 Falkens all around
Other ride:
'64 Dodge Dart 270 - blue and white (Color Me Gone style)
360 ci, 727 trans, posi rear, Preformer RPM airgap, Holley 550, custom headers, Flowmaster exhaust, no brakes!
Old 04-25-2007, 02:38 PM
JaySVX's Avatar
JaySVX JaySVX is offline
Typically 94+ have the different trans cooling system, so iwth a 96 you may not have any issues. I have a 94 with 129k miles and i'm trying to kill my tranny, but it just won't die. The 92-93 had a filtration system that was a bit to fine and got clogged, reducing cooling, causing over-heating, and killing trannys.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 05-22-2007, 10:17 PM
VectorNut VectorNut is offline
Send a message via ICQ to VectorNut Send a message via AIM to VectorNut Send a message via MSN to VectorNut Send a message via Yahoo to VectorNut
Do you have the model or part # for your cooler? Do I understand correctly that the one you have is the one used in the how-to? I couldn't find any mention of which one is used in the doc.
Old 05-23-2007, 07:43 PM
B&M all the way
Yeah, it's the B&M Supercooler, part # 70264. It looks just like the cooler in the How-to Doc, and mounts up the same way. It comes with everything needed to install, and I got mine from Dayle at SVX Motorsport. I think his price might have gone up a little since I bought mine, but it's a must have for SVX transmissions.
http://svx-motorsport-accessories.st.../trancool.html
p.s.
I might have this same cooler still in the box that I bought for something else, I'll check.
San Ill Delfonso
Other ride:
Old 05-23-2007, 09:41 PM
nexus_7 nexus_7 is offline
my 94 trans just died earlier this month. I have only had the B&M on for a year or so so all the damage was already done I have about 135000 on it. Gana have Bud replace it...once I can get it over there.
Greg
Old 05-24-2007, 10:23 AM
Thanks, their price was quite a bit higher than Summit Racing -- $89.95 vs. $61.95 -- but they have some other stuff I might be needing to buy from them.
p.s.
Crap. I should have read your post more carefully BEFORE I ordered one from Summit.
