Old 04-24-2007, 07:01 PM
cyberbackpacker cyberbackpacker is offline
WTB: 1995 Underhood Emissions Labels
I am in need/want of the two underhood emissions label of the emissions system for a 1995 that is in reusable condition... do not know if someone can peel one off nicely, or cut it out of the hood and let me try , or what, but... I am hoping to do an eg33 swap, and would like to have the 95 labels to correspond with my 95 body style to try and get through CARB emissions easier. My 95 Legacy is OBD-II and I am not sure if you can swap an OBD-I into an OBD-II. I am pretty sure you cannnot, but... since Fed Regulations weren't until 96 for OBD-II to be in place, it may get by a smog inspection if these labels are in place under the hood. The info I have found says as long as engine is same year or newer, changing engines is OK, so I am just in limbo and trying to do as much as possible to make this happen.
Thanks in advance.
Old 04-24-2007, 09:01 PM
You can order a set of both the emissions sticker and the vacuum lines routing sticker from your dealer (usually at no charge)
This is commonly done when a hood has been replaced due to an accident. When I had the hood replaced on my 96, I ordered a set from my dealer. I didn't know that the body shop had also ordered a set to install on my new hood. Therefore I have an extra set.
But they won't help you as mine is OBD II.
Old 04-25-2007, 12:18 AM
That is some very helpful information, I will check into that tomorrow! Thanks so much. Hopefully it will work out for me.
Old 04-25-2007, 04:29 AM
michael's Avatar
michael michael is offline
What Potholes ???
If someone can scan it for me, I would be happy to do the artwork to have replicas made. I'm trying to get a collection of all of them. So far I have the fog light warning, underhood fuse box and R12 A/C.
Wanted: Steering Wheel
Old 05-01-2007, 04:27 PM
A follow-up... tried to order the stickers from my Subaru Parts Dept. and they said they could not order the emissions sticker unless I was a bodyshop. Then they acquiesced and said with valid registration for the car and driver's license that they could order one for me.
So.... now I am on the lookout for someone with a 1995 California labeled SVX that wouldn't mind ordering a set of these under hood stickers for me?
