Old 04-19-2007, 08:46 PM
kwren's Avatar
kwren kwren is offline
ABS thingie that fastens to front wheel hub???
How do I disconect it so I can take the hub to a machine shop and get a new bearing pressed in?? Please don't say to take the bolt out.
I did that mbut it is stuck worse than you can imagine. Rust buster or something?? Please give me a clue if you have a good idea!
Thanks,
Keith
Old 04-19-2007, 09:01 PM
Soak it in PB Blaster repeatedly. Once it's soaked for a day use a drift to tap on the tab where the bolt went through to rotate it back and forth. Once you've rotated it a few times you should be able to get it out.
Old 04-19-2007, 09:10 PM
kwren's Avatar
Thanks for responding and you are so right..........God doesn't need wings!
