Old 04-17-2007, 04:39 PM
Dominus's Avatar
Dominus Dominus is offline
Homo Sapien Superior
Changing Spark Plugs
I want to change the spark plugs but there is this metal tube in the way on the drivers side. I was about to remove it when my friend said it was full of coolant. Is this true? And if it is how do I work around this? Any other tricks to changing the spark plugs or is it pretty straight forward as long as you can get to them.
“Veni, Vidi, Vici.”
Old 04-17-2007, 07:07 PM
immortal_suby's Avatar
Thread Killah
I'm not sure what tube you have there that would be in the way - can you post a picture of it?
Locker Link
2015 BRZ Limited 6MT
Old 04-17-2007, 07:21 PM
LetItSnow's Avatar
Still Cant' Say the Z-Word
I read something about pulling the wheel, and going through a door in the wheelwell to get to one of the plugs. Is this for real?
Old 04-17-2007, 07:41 PM
Yes, there is an hole with a rubber plug that can be taken out to get to one of the plugs.
Old 04-17-2007, 08:03 PM
MPtyza MPtyza is offline
Formerly MKP
Send a message via AIM to MPtyza
Something that I've found very convienent for changing spark plugs in tight areas is a spark plug socket with a built in u-joint. I was able to do the plugs on an SVX very quickly without needing to use the access panel or remove anything else. I got mine at Autozone for less than $10 (I believe, it was several years back)
1988 XT6 FWD 5MT 220k
Old 04-17-2007, 11:20 PM
We were talking about that type of wrench. Would you post a picture of it? Just like to see what kind you have. Thanks
Old 04-18-2007, 07:44 AM
Here is the typical U-joint spark plug socket
SK tools also has a completely flexible swivel socket with a ball-joint connection.
Old 04-18-2007, 10:10 AM
ShiuludeSVX's Avatar
Moss Covered 3 handled .........
Try these.
These are my Houdini Handles. They have tamed many transverse engine situations, so they should handle the SVX also.
The Worm
_______________
June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod"
Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012
'05 Infinity G35 Coupe.
No Mods, 33K Miles
Old 04-18-2007, 10:44 AM
Formerly MKP
Thats the type I use right there
