Old 04-15-2007, 11:29 AM
greggbzz's Avatar
greggbzz greggbzz is offline
Awitha Cheese-ahhh!
Send a message via AIM to greggbzz
Red face Sunroof advice
My sunroof stooped working last year. It doesn't move at all when I hit either button, just a very soft click. I can move it manually with the Allen bolt fairly easy.
I've checked all the fuses, relays etc.. The buttons do make that soft click somewhere by the motor assembly. After fiddling around with it when it first broke, I did try to adjust the clutch. That had absolutely no affect.
Any thoughts on what could be wrong? It just stopped working suddenly. It was going pretty good before then, just the occasional nudge was needed.
I'd like to know if it is the motor before I tear apart the whole thing.
It's on my before Reading todo list.
Old 06-08-2007, 02:50 PM
Did you ever fix it? Sounds like you'd have to remove the headliner and start probing wires.
Old 06-08-2007, 03:11 PM
Is is just a soft click, or any other sounds?
