Old 04-14-2007, 07:58 PM
svxthc's Avatar
svxthc svxthc is offline
URGENT: High PRESSURE PSTEERING HOSE
This is the main power steering hose that draws ATF, let me know if you have one and name a price. Thanks, Clayton
1993 SVX Anniversary Edition #64
Old 04-14-2007, 09:37 PM
Which one is it? Click here to see Picture
Old 04-15-2007, 09:26 AM
svxthc's Avatar
I'm pretty sure this is the hose.
Old 04-15-2007, 09:58 AM
That is the high pressure hose. It is #16 in the picture. It sells for 86.80 at subaruparts.com I don't know of any way to get around getting a new one other than a used one and it probably wouldn't last long. This is a common problem. The hoses are getting old and starting to go. The low pressure hose, or return line, can use a standard hose and doesn't have to be purchased from Subaru. Good luck
Old 04-15-2007, 03:02 PM
svxthc's Avatar
Thanks Ensteele, I'll go ahead and order it and then take the part into Midas for them to install it. They charge 80$. Is that worth it or can I do it myself? I imagine this involves bleeding the system. Right now that hole causes lots of air to get in and the car sounds like a sewing machine. lol
Old 04-15-2007, 11:36 PM
It is easy to install and you should be able to do it. After installing the hose, just go from hard left to hard right a couple of times and it will be ok. Just make sure the tank is full. Good luck. If you can't find a part number, let me know.
Old 04-16-2007, 06:02 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Mine's leaking too ...I have a foam piece of insulation on it....Is this standard with the hose or to keep the heat down?
thanks
1995 Subaru Svx L / AWD
