Old 03-29-2007, 08:52 PM
SVXgarcia SVXgarcia is offline
Send a message via AIM to SVXgarcia
Tranny fluid
Which tranny fluid should I use or what kind of tranny fluid do you guys use and how much does the auto tranny take?
Old 06-06-2007, 09:31 PM
No answer?
Just make sure it's not Type-F (Ford) or ATF+3 (Chrysler) and it should be safe
Old 06-06-2007, 10:36 PM
I have always just used the Subaru brand transmission/power steering fluid everytime I changed my fluid and I have never had a problem with it. Slight downside is that it cost a little more than ATF you could pick up at Autozone, Schucks,etc. I know that some people prefer synthetic fluid and it supposidly helps keep tranny temps down too. Also remember to change your internal and external transmissions filters when you change your fluid. I believe the transmission holds around 12 quarts I can't remember the exact amount.
Old 06-06-2007, 11:39 PM
When you change the internal filter, you will drain out quite a bit more than if you just drain using the plug.
Old 06-07-2007, 12:00 AM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
Originally Posted by Earthworm
No answer?
because it could easily be found some answers with some "searches"
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 06-07-2007, 08:56 AM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
Arrow Amsoil Synthetic ATF
Want your tranny to last long, go with the Amsoil Universal Synthetic ATF. Its well worth the investment. I had over 300k miles on my legacy awd wagon when I sold it, and it still shifted like new. If you sign up to be a preferred customer, you pay $20 a year and get wholesale prices. I use a lot of there products so the savings are substantial.
http://www.amsoil.com/StoreFront/atf.aspx
Old 06-13-2007, 03:08 PM
I just don't like seeing threads with no resolution. Perhaps this thread would come up as a search result.
Old 08-16-2009, 02:42 PM
Re: Tranny fluid
it did, and still NO ANSWER
