Old 03-16-2007, 02:21 PM
Dayton-Dave Dayton-Dave is offline
Dayton-Dave
Exterior drivers mirror question...
Can the glass mirror be replaced? How does it come apart if it does?
Old 03-16-2007, 02:57 PM
Hi Dave,
I have raised this question without a reply and so became involved in wrecking a mirror to find out the answers.
The assembly is very, very difficult to strip down and the key to it all is a screw beneath the mirror glass, so that it would appear that the glass is fitted during assembly, as the last item. It is retained by the grooved edge of the plastic backing piece and at first sight would appear impossible to replace without breakage.
However a local glass specialist, fitted a new mirror for me no problem, by using a heat gun to soften the plastic, as they do with all automotive mirror replacements. The original is convex so as to increase the field of view and I had to accept a normal flat mirror. Mine was on the passenger side so not so important.
It should be possible to get a mirror cut slightly small, so at fit inside the groove and then fix it place with a suitable thick adhesive, if you do not have access to to a glazing shop.
I hope you can sort it out, Trevor.
Old 03-16-2007, 03:46 PM
I have seen replacement mirrors for sale from time to time, but didn't know how it was done. It is too bad that you had to wreak a mirror to find out, but at least we know now.
Old 03-16-2007, 06:15 PM
Darren's Avatar
Darren Darren is offline
Hiya,
The JDM heated mirror glass is available from Subaru, if I remember rightly there was green or light smoke tint options, we had to order 1 for the 1st SVX we imported some 4 or 5 years ago.
Darren
11/94 SVX Alcyone, Mica Black, VL Spec 4WS, 71K Miles, 1 owner from new & was part of a private car collection in Japan.
Nissan R34 Skyline Stagea
91 Lotus Elan SE Turbo
1966 MGB Roadster, Tarten Red, Wire Wheels, Leather, 23K miles from new
You can tell the men from the boys from the speed of their toys.
Old 03-16-2007, 06:46 PM
It's Just Eric's Avatar
Missing in action
For most home handymen, it's probly better to replace the whole assembly. Try finding a used one. If it isnt the same color, you can likely have it painted easier than it would have been to replace just the glass.
hope you get your mirror sorted out
R.I.P Cool Signature.
Old 03-17-2007, 08:43 PM
Dayton-Dave
Guess what!!! They ain't glass!!!
I took a shot and thought maybe a little buffing with scratch remover and polish would make the scratches better. I was right....to a point. I was having great success removing the scratches. However one was a little deeper and I was now in the mindset to create a perfect surface.
Well, I went too far by two or three swipes. All of a sudden a dark smoke type of color started to surface then "Oh Nooooo!!!" the light brown color of the backing was showing thru!! Ruined, I could not believe I had done this. I mean how was I going thru all the way thru the mirrored surface?
I am used to the mirrored silver to be on the back and the glass on the front. That is for a glass mirror. This can't be glass. Obviously I couldn't have buffed thru truely a glass surface, just by finger pressure anyhow. Well, I have and the backing surface is indeed showing through.
So I have ordered a glass mirror from Carparts Wholesale. I am now going to find out the hard way how to replace this thing.
So if you have some light (I repeat light) scratches...they can be buffed out, just don't go too far. I was really giving it my all, I just was really elated that I was indeed getting rid of the scratches. I saw no signs of any layer rub thru, such as you might get when rubbing thru clear on paint.
Old 03-17-2007, 10:06 PM
I have never seen one broken, so this may be why.
Old 03-18-2007, 11:29 PM
The auto glass company I work in administration for employs a product called "Burco Redi-Cuts", which are essentially, custom-cut mirror glass replacements for most vehicles.($25-$35) At the shop, most technicians adhere these replacement glass over existing damaged glass (if it is still intact) and if the mirror is shattered, the technician would remove the remnants and adhere the new mirror with adhesive, usually Sika-Tack Urethane (heat and apply).
It is a relatively easy way to replace that broken glass instead of sourcing an entire assembly. (For most cars, at least)
I hope this helps.
Old 03-19-2007, 12:28 AM
Old Fogey
I hope this helps.
I've seen these on eBay on occasion at maybe $12-13 incl shipping. Sounds like an easy fix for cloudy/scratched original glass.
Glenn
Old 03-19-2007, 03:24 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
I hope this helps.
The previous owner stuck one of these on my Legacy. The only problem with it is when you use the mirror heaters. It takes a long time to melt the ice because the heat has to conduct through an extra layer of glass.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
