Old 01-31-2007, 03:33 PM
snoryda28 snoryda28 is offline
help....
my car has a problem i was driving the other day and it shut off and i stopped on the side of the road and turned the key it started right up but when i put it in drive and touched the gas it died so i started it again and put it in drive and didnt touch the gas it would crawl for about 20 feet then shut off i have no clue whats wrong with it any help?
Old 01-31-2007, 03:58 PM
Is it giving a CEL? If so check the codes.
Old 01-31-2007, 04:13 PM
SomethingElse's Avatar
word words wording
My mass air meter did that to me and it didnt throw any codes.
If your not getting a check engine light try lightly tapping on it. but check for codes first.
Eric
Old 01-31-2007, 04:18 PM
im not getting any codes ill go look again
Old 01-31-2007, 04:24 PM
now it wont even start just cranks
Old 01-31-2007, 06:14 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Do you hear the fuel pump running when you turn the key on?? Fold your rear seat down to make it easier to hear it. You should hear an electric motor run for about 5 seconds after you turn the key to ignition(not crank).
Old 01-31-2007, 06:22 PM
Yea the feul pump turns on i can hear that motor
Old 01-31-2007, 07:32 PM
Budfreak's Avatar
Banned
Check to see if you are you getting fuel from the output on the fuel filter.
Old 02-01-2007, 05:49 PM
sperry's Avatar
sperry sperry is offline
$1 is just $1, but $2 = nachos
I had the same symptoms and replaced my MAF which fixed the issue 100%. Motor ran like a champ afterwards (well until my knock sensor went!).
3 turbos, 28 cylinders, 96 valves, 18 cams, 1400hp/1600ftlbs: '09 Outback XT / '06 Outback Sedan / '02 WRX / '94 SVX / '01 F-250 SuperDuty
Old 02-01-2007, 05:52 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
the stab in the dark answer is going to be MAF but you should still find a way to make sure you have fuel pressure and spark right now or replace the MAF
- John
Old 02-02-2007, 10:45 AM
i think it might be the spark plugs because on some of them the housing is cracked i can see the wire on one of them.....
Old 02-02-2007, 11:13 AM
Darren's Avatar
Darren Darren is offline
Try disconnecting the MAF sensor and see if it will run, late 98 JDM impreza has the same MAF sensor and gives the same problem when they fail.
I had 2 go on mine withn 2 weeks of fitting an HKS induction kit, the car would run enough to move it/ crawl it home at low speed when the MAF was disconected.
Are you using the standard airbox or aftermarket bolt on cone filter?
The sensors are very unreliable with cone filters or any vibration.
Darren
11/94 SVX Alcyone, Mica Black, VL Spec 4WS, 71K Miles, 1 owner from new & was part of a private car collection in Japan.
Nissan R34 Skyline Stagea
91 Lotus Elan SE Turbo
1966 MGB Roadster, Tarten Red, Wire Wheels, Leather, 23K miles from new
You can tell the men from the boys from the speed of their toys.
Old 02-02-2007, 11:07 PM
alright ill see if that works its too cold and too much snow to go outside right now...my name is darren too hah
