Old 01-29-2007, 10:34 PM
tmak26b tmak26b is offline
green or orange coolant
what does the svx use?
Old 01-30-2007, 01:23 AM
Both? I've used either one and mixed them as well (not recommended but I change my fluids quite frequently). Doesn't make any difference far as I'm concerned.
If you really need to be pointed somewhere, just go with green.
Oh and since you are here, read up.
http://www.popularmechanics.com/how_...36.html?page=1
Old 01-30-2007, 06:26 AM
GREEN only please.
Our shop had a low mileage 3.1 Chevy, the head gasket leaked, the orange antifreeze got into the oil, turned the oil to jelly, and smoked the bearings!
Old 01-30-2007, 06:46 AM
DarknessofDeath's Avatar
Inhabitant of Darkness
that's not pleasant.
i use green myself
Old 01-30-2007, 11:22 AM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
I thought orange is the better coolant than the green?
But not sure if it's suitable for the SVX.
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 01-30-2007, 11:49 AM
As far as I know using one or the other doesn't really matter too much, but if you mix the two colours they can congeal into a goopy mess which will restrict coolant flow. If you get a full water flush putting orange stuff in might not do any harm, but why chance it.
When completely befuddled and terrified, just add water.
Old 01-30-2007, 03:45 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
There is a difference and cars are engineered for one or the other. Definitely never mix them.
Old 01-30-2007, 07:20 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
Originally Posted by svxfiles
GREEN only please.
but thats not due to the coolent its due to the fact that chevy lower intake gaskets were designed by apes... no i take that back... i dont want to offend any apes that might be reading this
by orange i think you mean Dexcool (sp?) which is GM's "extended life" coolent its crap, and gels up when its mixed with regular coolent or so i have been told (never actually seen it)... so unless your subaru turns into a chevy use green.
- John
Old 01-30-2007, 07:29 PM
I haven't seen any problem with anything gelling up. The only thing I would worry about is the corrosive potential on any steel or iron based parts.
I do try to run only green, and have done so for years, but there was one time I had some orange for whatever reason and I had to use it.
There were no apparent side effects.
Old 01-30-2007, 07:36 PM
Beav
Which one would you use in a SVX? I would guess Green.
Old 01-30-2007, 09:41 PM
SSSVX's Avatar
Is "green" was the stock coolant color for the SVX?
Some green coolant they're already pre-mixed with water and states is compatible with other brands?
-SSSVX
Old 01-31-2007, 04:08 AM
Green was the stock color antifreeze for the SVX.
Old 01-31-2007, 03:38 PM
Beav's Avatar
Not as old as Randy
Compatible with other brands does not mean compatible with other types.
Old 02-01-2007, 05:56 PM
Tiamat-red's Avatar
Tiamat-red Tiamat-red is offline
Following the path of the beam
If I remember correctly the problem with the orange(Dex cool), was that it corroded the interior bits of the system and caused clogs?
It does have "Organic Additive Technology", which sounds really cool, but was just developed to be more environmentally safer. Or less harmful I guess.
And then theres the DC red version which had the even cooler "Hybrid Organic Additive Technology".
Both of which were supposed to last for like 100,000 miles or something.
But I think they ended up being more harmful to the cars then the environment.
Dunno, but anything that is supposed to be environmentally safer sounds like it probably isn't as good to me.
Like catalytic converters.
Matt!
92 Ebony LS-L "Jabberwerwok" Now includes 1 *free "Wheeeeeee" per ride!
83 Honda Magna v45 "Grendel"
*Free after mail in rebate
Old 02-01-2007, 10:21 PM
I read the bottle of coolant I have and it says it's safe to mix with all other colors.
http://www.prestonezone.com/
