Old 01-28-2007, 11:04 AM
Crazypolo95 Crazypolo95 is offline
95pologreen
Send a message via AIM to Crazypolo95
Koni Inserts
I'm looking into getting some but I wanted to see what they look like on the car? Does any one have any pics. On and how they are set up
Old 01-28-2007, 03:08 PM
gwarusee gwarusee is offline
The actual konis themselfs wont change the looks or the svx, they are inserted down into the hollowed out stock strut housing. you drill your old struts let them drain and then pull em out, then replace them with the konis, konis are resistance ajustable and can tune your ride to be stiffer on the rebound, to lower/adjust the height of you svx you will have to go with a set of progressive rate drop springs or the ground control sport coil over setup, which requires you to cut your old spring pearches and weld smaller ones on. these are fully adjustable, konis and ground control coil over togther will give you the ability to make multiple adjustments to your suspension. search for konis and ground cotrol and there are quite a few threads with pics included. Im pretty new on here but have already found all the info on this topic that i have wanted just browsing old threads.
Old 01-28-2007, 04:32 PM
SVXelerator SVXelerator is offline
Frequent User
There is a multitude of pictures scattered amongst the lockers of various members of this esteemed network. Using the "search" feature you should be able to identify the members that have the pictures.
Maximum acceleration, maximum lateral g-force...it can be done, it just takes time and $$$
Old 01-30-2007, 06:06 PM
95pologreen
Well i have some Motorsport SVX G-Lateral Drop Springs but i need to get some new shocks. Just wanted to know if anyone has this kinds of set up on their car or would it be better for sale the spring and go with the Eibach set up? Or just keep the spring and go with the Koni struts?
Old 01-30-2007, 08:49 PM
Old Fogey
Why don't you ask Dayle at Motorsport? I'm sure he's got some pics of a car with that combo.
Glenn
Old 01-30-2007, 08:55 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
I have Mychailo's springs with Koni inserts on BillStock 4.0. Very nice set up. Pics in my locker.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 01-31-2007, 03:26 PM
snoryda28 snoryda28 is offline
i got some brand new konis ill sell em for 700 shipped to ur house i paid 775
Old 01-31-2007, 06:10 PM
95pologreen
yeah the ones that i found are like $700 with shipping. Also i need some new Coated strut. Does anyone know where i can get some new ones if not i'll just use the oem ones. I have some Motorsport SVX G-Lateral Drop Springs that i'm thinking of saling them to get this set up with the koni.
http://www.cardomain.com/item/GRO752502
Old 01-31-2007, 06:30 PM
i got u for 650 then...
Old 01-31-2007, 06:43 PM
95pologreen
are they still in the box? Wait about 1 or 2 weeks max and maybe a yes. Would a moeny order be cool?
Old 02-01-2007, 10:16 AM
yea they are i took one pair out to see if everything was there then put it back in the box there still in the box they got shipped in too yea money order is cool
Old 02-01-2007, 11:07 AM
mbtoloczko's Avatar
sans SVX
I can get you Koni inserts if you want.
Mychailo
Visit my locker
