Old 01-23-2007, 11:34 AM
3D Engine Stuff
So, for everyone who asked, I've started animating the 3D H-6 I made up. I appologize for the terrible quality, I'm going to use a better rendering algorithm when I do the final one.
http://smg.photobucket.com/albums/v2...ngineSpin1.flv
I'll update this when I make some more progress. Eventually the full valvetrain will be animated along with the crank and pistons.
Old 01-23-2007, 11:39 AM
I had no idea what you meant in the other thread. I thought you were making a logo or something
but this is pretty sweet.
I can see why you don't have time to do the entire car but you are using quite a few polys there.
Old 01-23-2007, 11:44 AM
I did make a quick logo type thing, a spinning picture of the Alcyone hood badge.
http://smg.photobucket.com/albums/v2...yoneEmblem.flv
Old 01-23-2007, 01:13 PM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
any way you guys could make these into avatar-sized gifs?
Brian
Old 01-23-2007, 01:52 PM
~*~JenSVX~*~'s Avatar
~*~JenSVX~*~ ~*~JenSVX~*~ is offline
J. Bond
Send a message via AIM to ~*~JenSVX~*~
lol Thats the first thing i asked the IT guy at work to do for me... He's goin to try and convert it for me.
J. Bond 7
1994 Laguna Blue
www.longislandsubaruclub.com
LISC member #50
Old 01-23-2007, 02:02 PM
J. Bond
Apparently without luck though...
J. Bond 7
1994 Laguna Blue
LISC member #50
Old 01-23-2007, 02:21 PM
The EG33 timing belt only goes around the lower 2 cam sprockets.....
But it looks really cool....can you convert it to a DXF file?
I use AutoCAD and would like to play around with it too
Old 01-23-2007, 02:55 PM
........and all the inlet valves don't open together.......and the crank is a 120* not 180*
Old 01-23-2007, 06:09 PM
to all of you!!! I started that engine as a flat 4 before I even knew what an SVX was. I know the layout of the EG33 timing belt, but this one took me something like 4 hours to make. I just don't feel like going through that again, and then making geared camshafts to match. The valves are all in their closed positions right now, I haven't positioned any yet, or moved the cam lobes to where they need to be to open the valves.
If an Avatar-sized logo comes out of this it's MINE , but I'll make you one if I figure out how, just let me know what you'd like, within reason. Keeping it under 100 kb might be tricky though.
Sorry Huck, I don't use an engineering program (ProE or 3DS Max or something like that). The program I use is called TrueSpace, and is meant solely as a graphics program. I can't save in different formats other than the program's own kind. I can give you all sorts of wire frame pictures of individual components though, and let you have fun with those!
Old 01-23-2007, 06:23 PM
A king hit for sure and there may be more.
But is it not unkind to suggest all are blind?
Old 01-23-2007, 07:18 PM
Ah no worries.
Update: I made a GIF file out of my spinning hood badge animation, but I recieved an error message saying I'm not allowed to upload animated images. I know I've seen one before though, I believe PhastSVX has a spinning torbo one. Arg.
Edit: It works (I think) if you link it from another site, photobucket and such. But the file is too big right now. More to come!
Further edit: I squashed the file down to the required size, but the quality is absolutely horrific, the thing spins way too fast, and there's an annoying headline across the top because I used the trial version of a software and there's no way I'm paying for the full version. Here's what I put together.
Old 01-23-2007, 07:50 PM
I can fix that, if you remake it with a little more space on top.
Old 01-23-2007, 07:57 PM
Coming right up! What format do you want it in? I can do AVI or GIF, or I can send you 100 individual images.
Old 01-24-2007, 11:08 AM
J. Bond
If you get this figured out let me know. And I promise not to use it as an avatar here. I wanted to use it on http://www.longislandsubaruclub.com So i'm sure no one else will have it since i am basically the only active SVX member on there
J. Bond 7
1994 Laguna Blue
LISC member #50
Old 01-24-2007, 11:16 AM
Ah, gotcha. Okay, I'll let you know when there's a working version of it.
