Old 01-08-2007, 02:02 PM
floatingkiwi's Avatar
floatingkiwi floatingkiwi is offline
A flight-less flyer
Send a message via Yahoo to floatingkiwi
Unhappy Rear discs are different between countries!
So, finally got back to NZ to put the new discs (ordered from Race Concepts) on my car - and discovered:
The new rear discs from the US are non-ventilated, and my JDM spec discs are VENTILATED! Argggh!
No need to mention they are completely different thicknesses.
What would you all suggest? Put the fronts on anyway? I assume the rear calipers are different as well, haven't actually pulled them to bits yet to see if there is any differences between them and the diagrams on Subaruparts website.
Suggestions?
'92 JDM (E) Burgandy/Black 100Km
Just Crusin'
Old 01-08-2007, 06:05 PM
send me your ventilated disks and calipers and I will send you mine
Old 01-08-2007, 07:42 PM
A flight-less flyer
Thinking, thinking......
Just Crusin'
Old 01-08-2007, 09:54 PM
JDW-SVX's Avatar
JDW-SVX JDW-SVX is offline
it's ruby red - not burgundy!!
Very odd - is your SVX NZ-spec or JDM-spec?
If NZ-spec SVXs had ventilated rear discs, I am at a loss to explain why my AU-spec SVX has solid rear discs!!!!
Jason.
1992 Charcoal Grey SVX - 165,000km
1992 Ruby Red SVX - 165,000km
....now with sequential VIN numbers!
1986 Holden (Isuzu) Piazza Turbo - 225,000km
1993 Mercedes W140 S500 Coupe - 153,000km
1990 Mercedes W124 300D - 313,000km
EG33 + 4EAT + VTD AWD = SVX
Old 01-08-2007, 11:10 PM
Suggestions?
Hi Matt,
You show that your car has done only 100,000 Km, but you appear to be involved in a lot restoration work. My car also imported like yours, now shows 156,000 Km and to all intents and purposes, is in perfect original condition. The odometer reading was confirmed by Japanese service receipts, I found in the car after purchase and were not known to the dealer.
The discs/rotore on mine are certainly not ventilated/drilled/slotted and are in good original condition. Could it be that the odometer reading on your car is not genuine, and the brake discs/rotors are not original?
Old 01-09-2007, 07:22 AM
From what I have come to learn is that AU spec cars have vented rear brakes
Old 01-09-2007, 03:03 PM
svxstarship svxstarship is offline
And here in Canada I have twice walked out of the local parts store (not the dealer) with Eurorotor Brand vented disks only to find the mistake later. Strange that they would carry these as they are all solid in N.A. To bad because the quality looked better than the stock solid ones. If i could get the correct calipers for the vented I would change.
1999 Audi A8. No more SVX's for now.
Old 01-09-2007, 10:50 PM
go back to the parts store and see if you can... If so, contact me... I want a set of rear vented rotors
Old 01-10-2007, 03:37 PM
dynomatt dynomatt is offline
Tom, the AU cars I've looked at are solid rears?
hence I used the JDM venteds on the rally car.
Matt, the caliper is different, so a swap to solids would need the solid calipers, and in my view, would be a step backwards.
They are the same disc as the WRX's, just with a different PCD, so one option could be that you get WRX ones and redrill, or alternatively, DBA offers blank rotors that you can get drilled yourself.
Old 01-10-2007, 06:20 PM
Can't get the right calipers here in Canada for the vented rotors. Legacy GT has same size vented rotors I think? Anyway I tried some used calipers from a Legacy GT and they did not fit. The calipers were ok, but the bracket is not wide enough. Anyone need some used Legacy GT calipers
Old 01-10-2007, 09:44 PM
so the mounting holes were not wide enough?? did the offset of the rotor and everything match?? If so, I may be up for them
Old 01-10-2007, 10:24 PM
The mounting holes were good. It was the part of the bracket that goes over the disk, if you know what I mean. I remember I could not just swap the brackets, I just can't rember why at the moment.
Old 01-10-2007, 10:25 PM
Oh sorry. The rotor was right on. Only diference was the thickness. Just looks nicer to.
Old 01-11-2007, 12:32 AM
NeedForSpeed NeedForSpeed is offline
Tom,
What happened to the Brembo project?
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 01-11-2007, 06:52 AM
I had about 35 other projectrs pile on top... I have been a very busy boy for the past month
TOm
