-Bill
My spare set here have an ID of about 62mm...that's EACH!
They flow some serious air! Matt |
Okay, I actually went out the garage and measured one of my spare TB and it's right there with Matt's -- ~63-64mm dia (each!)
Airflow through the TB is really not a problem -Bill
For those that are curious, dual 64mm throttlebodies is the same as a single 90mm throttlebody.
fixed your post. -Bill (72mm2 up on a 90mm TB)
ok...well 90.5mm to be more precise.
-Bill
Actually I would expect that our dual throttle bodies are much better than a 90mm throttle body. A 90mm (3.5 inch) throttle body opened 35% will let a lot more air through than dual 63mm (2.5 inch) throttle bodies will at 35%. This means you get a more linear throttle application with the duals than you would the single.
To bad we have a crappy idle control valve that is expensive as heck to replace.
Greg 97 Red SVX LSi clean 96 Black SVX LSi beater 90 Red Eclipse GSX track ho 99 Ford F250 work horse My Locker |
35% of 2 64mm TB = 2,252 mm2 35% of 1 90mm TB = 2,227 mm2 -Bill
David, yeah, every 0.5mm helps! -Bill
Just thought I'd clear this up. Harvey.
The full throttle areas in both cases are little different. 90 mm = 6361.74 2x 63 mm = 6234.5. It is also difficult to establish anything of advantage one way or the other, in respect practical linear throttle operation.
35% TPS reading does not mean that 35% of the surface area of the TB is open. It means that the TB plate is just over 1/3 of the way open. Technically you never have all of the surface area because of the shaft.
The larger the diameter, the faster the Airflow/%TPS ratio increases. Please correct me if I'm wrong as I am definitely not positive about this, however experience has shown this to be true.
