Old 12-08-2006, 02:45 PM
Cho Cho is offline
Send a message via MSN to Cho
Time to rebuild the Little L
I just got quoted today for 2250 to get a rebuild and installed transmission to be ready in about a week. So I decided to go ahead and have them do it on Tuesday. Its been sitting for about 2 months in 5 degree weather since it died out in October.
It should be done before the holiday so I'm still kinda excited about it.
And another question to the guys who knows a lot about this car. Should I install a transmission cooler to help prevent wear and tear on the low clutch packs? Because that seems to be the problem with my car at the moment. wont go into 1st, 2nd, and Reverse.
Cho
1995 SVX L - Emerald Green
1992 Supra Turbo Red
Mods: Slotted Front and Rear Rotors, K&N Stock filter, Blue LED Interior Lights, and New Paint.
Old 12-08-2006, 03:19 PM
Mr. Pockets's Avatar
Moderator
If I had a dime for every thread I had to move...
Yes, you should absolutely get a cooler. Living where you do, however, the transmission may take a really, really long time to get up to temperature in winter.
Glad to hear you're getting your car back on the road.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 12-08-2006, 03:22 PM
I'm sure it will be nice to have your car back and running. Its just my opinion, but I would definitely install an aftermarket transmission cooler.
Old 12-08-2006, 04:11 PM
Cho Cho is offline
Sorry for posting in the wrong spot. I really didn't mean to do that.
I guess I will install the cooler for the car then. For now its just figuring out the size. Maybe a 12" x 8" will be good? I would like to keep the temp a little under 200 degrees F if possible. I would hate to fix this car again within the next 2 years.
Anyways I live here in Alaska and its not really that cold. Only when we don't get any clouds for 2 weeks does it ever get that cold. Right now its 40 degrees out.
Cho
Old 12-09-2006, 05:29 PM
The ATF temperature has to reach 176*F/80*C, for the box to go into 4th, and the torque converter to lock up. If it does not, you will only get to 3rd.
When you fit the cooler, make sure that the ATF flows through the additional cooler first, then the engine radiator last, to ensure that the ATF does reach its operating temp.
Old 12-09-2006, 06:17 PM
DanSVX94's Avatar
DanSVX94 DanSVX94 is offline
Ren-Ma Osu
Dayle at Motorsports bought a L FWD model new from subaru tranny for $600 plus shipping charges about 5 months ago I think. You should see if he still has it. It lists for a lot more so I have no idea what he'd want for it.
Old 12-11-2006, 11:04 AM
Not that hot
Only 50°F is required for 4th. 150°F is required for torque converter lockup.
