Old 12-01-2006, 12:30 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Originally Posted by hexadec0079
OK, so after thunking to school without any sway bar bushing. I got home, and JUST finished up the install.
Note- the correct sized bushing helps, I bought ones that are 1mm smaller bore and bigger in all other aspects. Worked pretty well, squeezed 'em on. No play now!!!
Yeah I was thinking about the ECU crush mod as it happens in all gears, but not in neutral. So I don't think its the TPS, but I'll check. I'll do the crush mod tomorrow.
ATF fluid appears to be drips from PS system. Different shades (new tranny, old in the PS resevoir)
Budfreak is helping w/ Sol. A ***THANKS AGAIN***
Waiting for tomorrow night to do Seafoam and change. I am kinda worried about hydrolock, how hazardous is it really?
If you use the small vacuum line on top of the throttle bodies you should be fine. I've never hydrolocked an SVX yet and I've seafoamed about 8 of them now.
Old 12-01-2006, 04:38 PM
gwarusee gwarusee is offline
hey hexadec where did you end up having your tranny swap done, or did you do it yourself. a 4.44 swap is in my plans when the summer first starts(that is if my slowly dying tranny holds up) and I need to narrow down to where i want to have it done. any info would be great. Thanks , Nick
Old 12-01-2006, 07:00 PM
hexadec0079's Avatar
hexadec0079 hexadec0079 is offline
Parts Breaker, Tire Waster
Send a message via AIM to hexadec0079
Half done in my driveway, half at shop (Alltune and Trans.)
Very slow, but good, and quasi-affordable. A bit sketch, but good work.
UPDATE:
ZOMG!!!!!!! The LSD additive is the BEST fix evAr. Added about 2-3oz. And went for a drive. No more than 1 mile later and after some round-abouts at 20 mph, its sooooo much better. 90% better, I'm sure the rest is from the crappy alignment. Hesitation is much decreased, I'm not sure about the Ecu bead as it is too low in the RPM, but I'll try to get to it tomorrow.
List for Sat.:
-Seafoam
-Change Oil
-Change ATF
-Alignment
-ECU bead crush (double check Sol. C wiring)
-Pass. Sway bar bushing
Next Weekend:
-Brakes
-Secret suspension mods (shhhhhhhh!)
1992 SVX- -Drivetrain by BUDFREAK-
Green, LS with spoiler, 157,000, ES Swaybar bushings, 9005/6 mod, 2.25' Dual Exhaust, Custom Grounding, Hyperwhite fogs, LED tails, 4.44s, custom Blitz intake, tranny cooler, thats about it, for now...
1997 Chevy 1500 -FOR SALE-
5.7 liter, Z71, 300hp+, still almost 20mpg
1986 Merkur XR4Ti -SOLD-
SVO Engine, T3 hybrid turbo, K&N, custom ducting, Initial D painted, 18psi, fastest car for under $1000, ever.
