Old 11-28-2006, 02:41 PM
mhl0125 mhl0125 is offline
Send a message via AIM to mhl0125 Send a message via Yahoo to mhl0125
Water, water everywhere!!!
I know this has come up before, but I can't find the appropriate solution. My carpet on the right (passenger) rear side is soaked. Therefore, my windows all steam up overnight with condensation. I know there are drains everywhere and perhaps one or more are clogged. Where do you suggest I look for the drains and how do you clean them? Thanks.
Michael
1994 Barcelona Red SVX-LSI
Two-owner:169K
1995 Emerald Green SVX L AWD
#80 - Custom intake w/cone filter
99K with killer stereo system
2002 Acura MDX-Touring Edition w/navigation
2008 Toyota Prius
1987 Mercedes Benz 560SL
Old 11-28-2006, 03:15 PM
nordique14's Avatar
Who watches the watchmen?
Is it actually water? It may be engine coolant. A failing heater core will dump coolant in that spot.
Old 11-28-2006, 04:05 PM
ShiuludeSVX's Avatar
Fluid
Notice any kind of a Gummy Smell?
Antifreeze smells a bit like that when the mix comes out of a Heater Core, and through carpet.
Slippery fluid?
The Worm
_______________
June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod"
Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012
'05 Infinity G35 Coupe.
No Mods, 33K Miles
Old 11-28-2006, 04:53 PM
I doubt if is a heater core leak if it is on the rear area of the passenger side. Put some paper towels down on the carpet to absorb the moisture and see what color comes up. if its clear or slightly dirty, its probably just water; yellowish-green would be coolant
It could be the sunroof drain on that side. Check this thread:
http://www.subaru-svx.net/forum/show...sunroof+drains
You can also do a search for "wet carpet" or "sunroof drains" (without the quotes)
Old 11-28-2006, 05:54 PM
It is definitely water, not coolant.
Michael
Two-owner:169K
2008 Toyota Prius
Old 11-28-2006, 08:16 PM
oops
oops,, Reading to quick. Guess I picked the wrong week to stop ........
The Worm
_______________
No Mods, 33K Miles
Old 12-04-2006, 03:01 PM
There are also little drains in the trunk behind the rear wheels. These are in addition to the sunroof drains. They are hard plastic and will plug up over time.
You would have to take the trunk liner (and wheel liner) out to get access to them.
