Old 11-28-2006, 01:17 PM
etz bseder etz bseder is offline
Hey, I need help/parts
I have a problem with a cracked intake hose/part. the part that says refer to item 7 is cracked AND the opposite end of that hose is completely split. I need help finding parts/ something that will work to seal it. I was thinking cauck on the piece itself, and a heat shrink tube placed around the end of the hose. I am unable to put on a new hose, because of the way the bend is in the hose, i am unable to get it on. If anybody has any advice, please help.
'92 LS-L, exhaust, intake, audio, ecu 1V4?, hyper ground kit.
Next changes ... PAINT, fix engine problems, 4.44. (GONE)
'97 Impreza Outback Sport, magnaflow muffler, cold air intake, Alpine Type S, MP3/iPod deck, NGK wires, etc.(GONE)
Old 11-28-2006, 03:04 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
If it's an air hose, then you can use glue, electrical tape, a tie strap. This of course is a temp fix. You need a tight seal, so don't use caulk, it's messy and expands with the heat. good luck!
Old 11-28-2006, 03:52 PM
That hose is the left hand side cam breather, it is not vital, but you don't want air being drawn in there either. You can seal it with a Silicon Silastic sealer, or buy a new one..
