Old 11-27-2006, 08:24 PM
nick_kas nick_kas is offline
Angry vibration in rear of car
I was wondering if anybody had an idea about what the problem with my car is? I have a 92 Svx and the rear of the car is vibrating pretty bad. It happens when accelerating and decelerating. It happens from 0 to 10 miles per hour both ways. any help would be awesome. Thanks
Old 11-27-2006, 08:33 PM
Hohopirates's Avatar
Hohopirates Hohopirates is offline
Tires?
If nothing else appears wrong, I would check out the tires first. My truck was making an odd noise and a vibration was present as well, it ended up being a defective tire. If not, it could possibly be rear diff problems. Steve
It's not a car..it's a boat!!
Old 12-04-2006, 01:38 PM
I doubt it's tires unless it happens at higher speeds. Any other info you can provide for us?
Old 12-04-2006, 03:47 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Rotate your tires to see if the vibration moves location.
Old 12-04-2006, 05:30 PM
The symptoms as reported would indicate faulty rear transmission mounts. Edit P.S. i.e. diff. assembly. If so, do not panic as not too expensive a fix.
Old 12-04-2006, 06:06 PM
sicksubie's Avatar
I have the same issue in my '92 as well. Symptons are identical.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 12-04-2006, 06:35 PM
nysvx10 nysvx10 is offline
My guess would be bad joint on the driveshaft, I had that on my car. Is it coming from around the center console?
Old 12-05-2006, 05:23 AM
sicksubie's Avatar
Mine is definitely coming from the back of the car. I am 100% positive
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 12-05-2006, 01:41 PM
Old 12-31-2006, 09:03 PM
chitownsvx chitownsvx is offline
rear differential
My car has that and I had the car looked at and the mechanic said it's the rear differential.
Check me out and tell me what you think.
And vote on my poll.
http://www.cardomain.com/ride/2148680
This is the day I got my svx, and took it for a test drive, while helicopters watched.
http://videos.streetfire.net/search/...6373e299d2.htm
Old 01-02-2007, 03:47 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Try inserting the FWD fuse and driving it a bit. If the problem goes away you have an issue to the rear, if the vibration remains look forward. Inner cv joints can cause vibration under accel/decel conditions without noticable hi-speed vibration. Driveshaft u-joints can also create this type of vibration under load, rarely during decel and are almost always accompanied by squeaky noise during accel. Or at least a good 'whang' when placed in gear from park/neutral or a change of direction.
Differentials rarely cause vibration at low speed, unless they have been making hi-speed vibrations/noise for a long time. Typically, differential noises come from worn/damaged bearings. Mesh noises occur either a) immediately following a rebuild or b) after bearing damage has occured and allowed the mesh to change.
Old 01-02-2007, 05:26 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
A bad tire (slipped belt) will often show itself as almost a boat-likes swaying of the car at low speed.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
