Old 11-22-2006, 12:25 AM
Dessertrunner's Avatar
Engine power when in default mode
Matt and I were talking about what would happen if he leaves the O2 sensor disconnected. I was of the opinnion that the ECU would go into default mode and run off standard maps.
Our question is will that reduce the power the engine puts out or not.
Old 11-22-2006, 02:35 AM
I thought someone ran without O2s and found it was faster, but had trouble when they tried to reconnect them?
Old 11-22-2006, 04:09 AM
ItsPeteReally ItsPeteReally is offline
A one word answer is probably.
A longer answer is that any default mapping has to be safe, that means that it has to be richer than optimum, as weak mixtures can lead to overheating, pre-ignition and engine damage.
So the default fueling maps have to be rich for all engines coming off the production line that lie within normal production tolerances. So for any particular engine, the results could vary somewhat. Add to that the fact that any SVX engine will have tens of thousands of miles of wear by now and the problem becomes even more difficult to analyse.
So the answer remains probably.
The saving grace is that the power output is not particularly sensitive to fuel/air mixture; you might see the difference on a dyno, or the dragstrip, but in normal usage this would go unnoticed apart from a slight worsening in fuel consumption.
I often say that when you can measure what you are speaking about, and express it in numbers, you know something about it; but when you cannot measure it, when you cannot express it in numbers, your knowledge is of a meagre and unsatisfactory kind; it may be the beginning of knowledge, but you have scarcely in your thoughts advanced to the state of Science, whatever the matter may be.
Sir William Thomson
Old 11-22-2006, 03:07 PM
O2 sensors.
I don't think it will matter, as far as power goes. When the foot is down hard, the TCU doesn't care about the o2 readings. It is reading the full throttle, full power, map.
Old 11-22-2006, 11:30 PM
THanks guys what you say makes great sense.
Tony
