Old 11-19-2006, 07:04 PM
DanSVX94's Avatar
DanSVX94 DanSVX94 is offline
Ren-Ma Osu
Driver's wiper sticks and is noisy
My driver's side windshield wiper sticks on the left side and kind of goes past window frame edge. I actually have to stick my hand outside while driving to get it unstuck. It gets stuck easiest at slower speeds. Any suggestions?
Old 11-19-2006, 07:25 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Remove the cover, the cotter pin and nut on the end of the arm . Then remove the arm and reset it untill it does not go over the edge when fully extended. This might take a few times to get it right. Tip: if you have trouble removing the arm, straighten out the arm by holding down the center while lifting it out. Good luck.
Old 11-21-2006, 07:14 PM
DanSVX94's Avatar
Ren-Ma Osu
Thank you. I guess I messed it up when I repainted the wiper arms during the summer.
Old 11-21-2006, 07:29 PM
Speedklix's Avatar
Locker Link Solution
Originally Posted by dannmarr
the cotter pin
I don't remember a cotter pin on the svx arm. I wonder if that has anything to do with why mine pop out a few degrees. Must take a closer look.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 11-21-2006, 11:12 PM
dannmarr's Avatar
I work for my SVX
You are correct, no cotter pin. That was my Dodge.
