Old 11-17-2006, 10:05 PM
hexadec0079's Avatar
hexadec0079 hexadec0079 is offline
Parts Breaker, Tire Waster
Send a message via AIM to hexadec0079
Looking for some help with wheels
Looking at some rare rims (its a secret) they are 17x7 offset +32.
Those should fit, but what size tire can I run??
Thanks, I know I post a lot of these noob wheel questions, but I am unfamiliar with aftermarket wheels.
1992 SVX- -Drivetrain by BUDFREAK-
Green, LS with spoiler, 157,000, ES Swaybar bushings, 9005/6 mod, 2.25' Dual Exhaust, Custom Grounding, Hyperwhite fogs, LED tails, 4.44s, custom Blitz intake, tranny cooler, thats about it, for now...
1997 Chevy 1500 -FOR SALE-
5.7 liter, Z71, 300hp+, still almost 20mpg
1986 Merkur XR4Ti -SOLD-
SVO Engine, T3 hybrid turbo, K&N, custom ducting, Initial D painted, 18psi, fastest car for under $1000, ever.
Old 11-17-2006, 10:07 PM
SomethingElse's Avatar
word words wording
I ran 225-45-17 but your rims are more narrow so i may run 215-50-17
Eric
Old 11-17-2006, 10:12 PM
wow, holy rapid post bat man. Thanks for the help though
Old 11-17-2006, 10:25 PM
word words wording
timing is everything...just ask ebay okay im putting the vodak down
Eric
Old 11-17-2006, 10:54 PM
Vodak huh? Must be that new-fangled stuff. I'll have to try some of that...
Old 11-18-2006, 07:57 AM
wawazat??'s Avatar
Yeah, I'm still around
A request for you. Can you please place your request in the proper sub-forum? Thank you very much and good luck with your new wheels and tires.
My input is to select a tire you like and then check its tech specs where you will find a recommended rim width for that tire in that size.
FWIW, I have 17x7.5, 48mm offset with 225/45-17, 17x7.5, 48mm offset w/235/40-17, and 17x8, 53mm offset with 235/40-17 tires for my SVX. I'm not a fan of reduced offsets on the SVX, though many people use them.
Down to none
Old 11-18-2006, 04:05 PM
there is no sub-section for wheels, only for Super, Turbo, and Ecutune.
But thanks for the input.
I think that a slight reduction of the offset will decrease levered loads against the bearings. But what do I know
Old 11-18-2006, 05:05 PM
elninoalex's Avatar
elninoalex elninoalex is offline
Registered Abuser
I ran a 17 X 7 before and 225/45 17 seemed to be just right for it.
