Old 11-03-2006, 02:19 PM
trieck1232 trieck1232 is offline
Send a message via AIM to trieck1232 Send a message via MSN to trieck1232
Bad gas milage
another question it has been braught to my attention that 16mpg is not good for my svx awd, andy ideas ive changed the air filter, fuel filter? plugs?
car runs like a top not sure hwat to do!
---Travis---
Old 11-03-2006, 02:44 PM
Dza's Avatar
Dza Dza is offline
#073 of 301
cars101 spec page has (for a 92 anyhow) Fuel economy: 17 city, 25 highway. 16 is normal. Better than I get, that's for sure.
Dan M.
Barcelona Red '93 AE #073 of 301, 168k miles.
Old 11-03-2006, 02:45 PM
i have a 95 mabie its fine who knows!
---Travis---
Old 11-03-2006, 02:56 PM
Manarius's Avatar
Manarius Manarius is offline
92-97, the engine in the SVX stayed exactly the same so MPG would be very very similar.
If you're really that concerned about it, replacing the knock sensor and O2 sensor may help you out a bit. It also helps to not drive it like you stole it.
-Jason
-Obi Wan Kenobi
Old 11-03-2006, 03:10 PM
GOT2HAVESVX's Avatar
GOT2HAVESVX GOT2HAVESVX is offline
What blue lights?
Send a message via AIM to GOT2HAVESVX
" It also helps to not drive it like you stole it."
How do you know he does this LMAO! I know thats kind of a given right?
Life begins around 70 MPH and stops when you dont see the flashing blue lights anymore!
Scott & Audrey's Subaru SVX's
1995 Green
1992 Black
Old 11-03-2006, 03:30 PM
heeh well i kinda do my transmision has been replaced 3 times the last time i meet a guy here in iowa that is reaaaaaaaallllllly good he knows his svx trannys we beefed it up havnt been able to break it yet fingers crossed been 4 years now, when do you guys/gals think the fuel filter needs replaced? its the easiest fuel filter ive EVER seen to change cept for my lawn tractor and wehre are the knock sensors and are they hard to change? done the pcv the other day that was way easier than i thaught it would be
---Travis---
Old 11-03-2006, 05:15 PM
  • How far are you driving
  • How often do you drive
  • How are the road conditions
  • What is the average temperature and altitude
  • What grade fuel are you using
  • Was this a sudden change in MPG
  • What MPG were you getting before
Old 11-03-2006, 07:16 PM
SomethingElse's Avatar
word words wording
Maybe you got a chip in it.
Eric
Old 11-03-2006, 07:20 PM
50/50 split highway and city not romping on it i like to go quick but not ever over about 3 grand on the tach, im above the sea in iowa and mabie i do how would i check if i have a chip in it?
---Travis---
Old 11-03-2006, 07:23 PM
word words wording
it might have a red wire coming out of it if they decided to use the optional setting. if they didnt you would have to take the ecm down and take the 4 screws out and look in it.
Eric
Old 11-03-2006, 07:25 PM
this is over the drivers feet correct, this is where i found the tach wire for my remote start install
---Travis---
Old 11-03-2006, 07:30 PM
word words wording
yea theres 2 modules together a brass looking color one and a flat silver one, ecm and tcm. qty3 10 mm bolts hold them on.. the ecm is the silver one
Eric
