Old 10-24-2006, 01:54 PM
LarryGreen LarryGreen is offline
mean.green.machine
Front-End Vibration on Highway
My SVX rides fine on the highway until I turn the wheel right or left. As its being turned, there will be vibration at the front end, sort of like the wheels are out of balance. It only happens when turning the wheel at high speed; when going straight, the car is fine. Any thoughts?
And, is this something I can fix without having to go to a mechanic?
Thanks.
Old 10-24-2006, 02:39 PM
DarknessofDeath's Avatar
Inhabitant of Darkness
i believe that if your .....actually no.
i have a warped rim right now and it vibrates on the highway speeds...not much noticable on city
Old 10-24-2006, 02:41 PM
I'd be guessing but probably something to do with your axles/CV joints.
Old 10-24-2006, 03:16 PM
Mr. Pockets's Avatar
Moderator
If not that, then it could be a ball joint. On the old Legacy we had, the car would start vibrating while turning on the freeway. By the time I got around to it, the ball joint was almost gone. I wish I had taken a look at it sooner - it was the car my wife drove to work every day, and I shudder to think about the ball joint failing and causing her to lose control.
So get it looked at. Now. I'm not trying to be mean, I just think it's important enough that you get it looked at before you drive it any more.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 10-24-2006, 04:07 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Check your air pressure, alignment, balance, power steering fluid, and any uneven tire wear, try rotating the tires to see if the sound follows. Could be that simple, We hope.
Old 11-10-2006, 03:17 PM
mean.green.machine
Thought I'd close the loop on this. I took the car to an NTB to have my tires balanced, since it had been around 10,000 miles since the prior balancing. They also did a front end alignment.
Now, I figured that since I didnt have the vibration problem when driving in a straight line on the highway (only when making a high speed turn); that it couldnt have been the tires being out of balance, or a front end alighnment. But that was apparently the problem, because the problem has gone away.
Old 11-10-2006, 04:27 PM
Your feedback is indeed appreciated and worthwhile. There can be two distinct forces generated if a wheel/tyre is out of balance, vertical and or lateral, (sideways). You appear to have had the latter.
It will be noticed that if a proper balance is being performed, weights are placed strategically, i.e. clipped on the outside or inside of the rim, or attached central by double sided tape. Sloppy balancing is a common problem. Stick with the outfit which fixed things for you.
