Old 10-22-2006, 10:30 PM
hexadec0079's Avatar
hexadec0079 hexadec0079 is offline
Parts Breaker, Tire Waster
Send a message via AIM to hexadec0079
? About Rear Diff
Since I have been unable to find a cheap local diff, I found this one on ebay. Will it wotk, or am I still gonna need to transfer the case?
http://cgi.ebay.com/ebaymotors/JDM-S...QQcmdZViewItem
1992 SVX- -Drivetrain by BUDFREAK-
Green, LS with spoiler, 157,000, ES Swaybar bushings, 9005/6 mod, 2.25' Dual Exhaust, Custom Grounding, Hyperwhite fogs, LED tails, 4.44s, custom Blitz intake, tranny cooler, thats about it, for now...
1997 Chevy 1500 -FOR SALE-
5.7 liter, Z71, 300hp+, still almost 20mpg
1986 Merkur XR4Ti -SOLD-
SVO Engine, T3 hybrid turbo, K&N, custom ducting, Initial D painted, 18psi, fastest car for under $1000, ever.
Old 10-22-2006, 10:34 PM
Manarius's Avatar
Manarius Manarius is offline
Looks like to me that that's the entire thing. Bolt that baby up to some axles, the frame, and a drive shaft, and you'd have a party.
-Jason
-Obi Wan Kenobi
Old 10-23-2006, 08:02 AM
They do not show the inside of the rear end housing, but from the different axles it appeares to be a LSD.
And they claim the ratio is 4.44.
I can get for you a 4.44 open diff for about $100.00 plus shipping, and you could convert it using your SVX LSD.
But it would be easier to get a factory set up.
If it fits.
Old 10-24-2006, 10:42 AM
Would the driveshaft input be any different?
Even if I use a normal Outback Diff and swap the LSD carrier, the input shaft would still be the same, right?
Any assistance would be grateful, thanks.
Old 10-24-2006, 12:12 PM
Measure the driveshaft flange and hole spacing.
As I remember the only time the flange did not fit was on a 4.11 swap.
So I had to remove the flange from the SVX and install it on the 4.11.
Old 10-24-2006, 04:46 PM
the flanges are easy to swap... just mark where they are and count the thread and put the new one back in th same spot
