Old 09-11-2006, 01:30 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Originally Posted by Earthworm
What else have you tried? I get this happening to me during (after?) autox runs and I would like it to stop!
David,
I'm hoping that the small billet tank will fix it....we'll find out this weekend
-Bill
p.s. I also run WaterWetter...
Retired NASA Rocket Scientist
Center Network Member #989
Old 09-13-2006, 05:52 PM
Originally Posted by shotgunslade
Removing the grill helped mine, along with adding Water Wetter to the coolant. Also, driving around 20mph or so for 5-10 minutes after the run, rather than just shutting it down. Now will open radiator cap after the engine cools down and top off with water every time, .
Dan it's not a good idea to open the cap, once the system is full. The whole idea of the expansion tank, is to keep the system full of water, and exclude all the air. Air in the system causes corrosion, and allows air pockets in the head and block to cause local hot spots.
If it is full and working, as the water heats up and expands, it pushes water into the tank. When it cools down it draws the water back to the engine. If you keep opening the cap air will enter the cap and overflow pipe, this air can prevent the water from being drawn back into the engine.
If the engine has been hot, don't remove the cap, while there is any pressure still in the system. The pressure raises the bolling point of the water, which boils at 100*C, but may be at 103*C. If you open the cap, and let the pressure off, all the water will boil instantly.
Allways feel the top hose first, to see if there is any pressure before you remove the cap.
Old 09-14-2006, 03:27 PM
shotgunslade's Avatar
Harvey:
Thanks.
