Old 08-06-2006, 06:57 PM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
Originally Posted by SVXRide
Chuck,
Couldn't the "cheap" intake filter Phil used just have collapsed under the boost load, then "sprung" back once the boost dropped off?
-Bill
The filter itself does not collapse, but you are right on in what is happening. THe silicone couplers and elbow suck in and restrict the motor. ITs not hard to have that happen, and its better that that happens then having hard pipes.
With a restrictive filter and all hard piping i would just have the turbo working extremely hot all the time, due to the fac that the turbo will have to work much harder to reac the same pressure level.
~Phil
Old 08-06-2006, 07:31 PM
cdigerlando cdigerlando is offline
Your Setup
I don't understand. Why not have the best of both worlds. I guess I need to take another look at your setup.
Chuck D.
1992 Subaru SVX LS-L - Heavily modded turbo
2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods
Old 08-06-2006, 07:46 PM
Phast SVX's Avatar
best of both worlds? The problem is the filter does not allow free flow so the elbows get sucked in between the turbo and filter, which will choke the engine and cause vacuum, even if it doesnt suck completly closed. Think about it, if there were hard pipes then then turbo would have a rediculously lower density ratio(heat, turbo is working harder ) to reach the gated pressure ratio. This situation would be hard to diagnose.
phil
~Phil
Old 08-07-2006, 12:43 PM
Hard pipe.
phil
I was thinking of perhaps hard piping the elbow. That way it won't collapse.
Chuck D.
Old 08-07-2006, 09:50 PM
Phast SVX's Avatar
switched to a k&n filter and all is well again.
phil
~Phil
Old 08-08-2006, 09:24 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
phil
As it should be! Now, get out there and make more Hp!
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 08-08-2006, 04:58 PM
Phast SVX's Avatar
-Bill
working on it although why should i tell you?! never sharing anything!!!
phil
~Phil
Old 08-08-2006, 09:13 PM
SVXRide's Avatar
phil
there's always PMs
-Bill
Old 08-31-2006, 12:36 PM
Track Tests
What's up? Are you back on the road? Have you had a chance to go to the track? Inquiring minds would like to know.
Good Luck
Chuck D.
Old 08-31-2006, 12:45 PM
Phast SVX's Avatar
Good Luck
Back on the road on gasoline, soon to be on the road with ethanol.
follow here if you want, its my progress thread
http://www.subaru-svx.net/forum/show...=31759&page=10
~Phil
