Koni insert woes
I just removed my rear struts and replaced the K&B springs with Mychailo's springs for 5MT rides. Anyway, I re-assembled everything and installed in the car. Now I have a rediculous knocking from the driver's side rear. Strut top nut is tight as are all 3 nuts that hold the assembly to the body. I didn't do the 2 bolts that hold the strut to the hub, but my roomate swears he tightened both and I believe him.
So, I'm a little worried it's something internal to the strut. Anybody have similar experience? Anybody know how I can check my strut top mount? Thanks in advance. Mat
Time for my very own long list of mods: 92 SVX LS-L - Ebony Pearl - 2002 WRX 5MT trans w/STi gearset (rebuilt & installed myself ) - BMW E46 HID retrofit - Kenwood Headunit - Phoenix Gold 75x4 RMS amp - Alpine Type R 6.5" front components - Alpine Type R 6x9 3way rear speakers - 18"x9" Rota G-Force wheels w/225/40ZR18 Toyo T1R's - Mychailo's custom springs - Urethane front & rear sway bar bushings - KC exhaust (2.5" dual magnaflow) - Escaine seat swap - Removed Spoiler I don't care if Subaru says it's STI...it will always be STi to me |
Mat,
You lagger, when can I buy that little plastic piece from you for the rear window? Sorry bout the hijack...
Insert Witty Quip Here... No more subie Current Cars: 96 Chevy Caprice Impala SS clone 93 Chevy Full-size blazer Soon: 2002 Honda CBR 954RR |
What piece do you need? I don't even remember.
BTW...you're a lagger too...you still haven't been down to check out the rides. Some additional info on this knock... It's worse under deceleration (rear end unloaded) It is louder over small road irregularities rather than defined inputs like lane markers. One quick question... COuld the little metal "hat" that goes between the top of the strut piston and the bottom of the inside of the upper mount make that kind of noise? I suppose it could. I'll check that first tomorrow. BUT, assuming it's not that, any ideas? Mat
92 Honda CBR 600 95 Miata |
Aight...I'll chegg it out tonight. Also, today on the way to work I remembered that I never fully tightened the lug nuts on that side (they were at maybe ~30ft lbs). So, I'll check that first.
Anybody ever had problems with Koni internals? As long as it's not that, I'm cool with it.
sway bar is fine. Spring seats are always tough to look at...I don't know how they're supposed to look. They don't have any visual damage. It's not collapsed or anything. I don't even know what I would look for on that.
Wow. I have that same problem. For me it was a weird slapping sound and once I hit a major pothole now it squeaks and rattles like I have marbles in my rear deck. Mine was checked out and I do believe it needs the lower rear spring seating, as I have brand new struts, upper seating, and strut mounts but I didn't think I would have to replace the lower seatings.
Tim 92 Liquid Silver SVX 5MT 2009 BMW Z4 (Gone) 2012 Camry V6 SE |
I checked the strut shaft bolt and I'm 100% sure it's tight. Plus, I have had the problem that you mentioned in the past...where I didn't have it completely tight and got the annoying rattle. This is definitely a different sound. In all honesty, I'm leaning toward the lug nuts not being tight. I've made that mistake on the front before, and it was basically the exact same sound. Thanks for the opinion, though. If the lug nuts don't work out, that hat will definitely be the next thing I investigate.
BTW, I really like the rear ride height. Compared to the K&B's, your springs are probably close to a 1" or 1.5" lift. My butt was sagging with those K&B's. Looks good! I could tell the spring guys must've been in a hurry to get these out because there was what appeared to be paint in the box from the springs (even though I thought they were powdercoated). Oh...I think I still owe you some $$ for these, don't I?
matt
its Dayle in tucson Im in need of some used parts, email me when you get a sec thanks dayle@motorsportwarehouse.com
My mom will forever live in me and never be forgotten, one day Ill see her again CLICK the LINK below to Visit the SVX Store: http://www.planetsvx.com http://www.motorsportwarehouse.com/svx/sig2.jpg Cars in the garage: 92 Toyota Soarer Single Turbo JDM RHD 70 Boss 302 Mustang 39k original miles 97 SVX Lsi 92 Liquid Silver Murano-ized (1st of its kind) 71 Cougar Xr7 Conv 351c 4v 4spd 69 SS Camaro 350 71 Nissan RHD Fairlady Z 70 Stang Fastback 70 Amc AMX 390 71 240z 89 Conquest TSi w/ 5.0 v8 swap 84 Mustang GT Turbo conv "good, if it bleeds, we can kill it ....." |
Turns out I'm just stupid
It was the lug nuts. Thanks for your time, but it turns out I'm just an idiot
Makes you feel dumb and fantastic that it isn't a "real" problem, though, doesn't it?
On a side note... do your Konis make a kind of swishing noise (from the rear ones)?
-Aaron SVX: '92 Dark Teal 101k '97 Legacy GT Wagon: dead '99 Civic Si: daily driver... stolen and stripped with all my tools! '92 Yamaha FZR 600: garage 2011 Jetta: Daily disappointment |
Thread Tools | |
Display Modes | |
