Security Module and Keyless entry module
Where on a 95 SVX would the Security module and the
Keyless entry module be located? Besides the Security module, what else is necessary to add the security feature to a car without one? Thanks Chuck E. |
My 95 has sensors in the door handles.
So in addition to the module, which on a RHD car is behind the rear right panel and armrest for the back seat window winder. Matt |
Harvey,
tony (aka Desertrunner) mentioned this, but he wasn't sure how it worked. Do you know how it works? Each time I lock it, then check it's locked, it beeps at me...then each time I lift the handle again, it keeps beeping at me. Matt |
What about the keyless entry module?
where is it located? or is it part of the security module? Thanks Chuck E. |
Edit: You'll need a wireless transmitter key fob too, of course.
David C. 1996 Laguna Blue Pearl SVX L AWD See my home page for SVX radio install/removal instructions and wiring harnesses |
You need more then just the module and remote. I have the last OEM factory accessory alarm from Subaru. It works for all dual air bag model SVX's. Besides the obvious alarm module and remotes to make it work you need the relay harness that plugs in under the dash near the steering wheel and the security switch.
Victor |
The process for doing the keyless unlocking, is here in my locker. http://www.subaru-svx.net/photos/user.php?oab_au|37061 Harvey.
I would imagine that the same switch contact that turns on the
nightlight around the keyhole acts as the sensor that makes it beep when you lift the handle. What is this wiring harness near the steering wheel? what does it connect to? Thanks Chuck E. |
hmm ... since we are here... does the svx have a transponder whatnot on the keys?
