Old 05-26-2006, 04:52 PM
strange179 strange179 is offline
Still a member
Send a message via ICQ to strange179 Send a message via AIM to strange179 Send a message via Yahoo to strange179
manual trans interchange
OK, without getting into too much detail, I need to replace my 5MT....again. I'm interested in the posibility of getting a lower milage tranny this time, Thing is that most of the lower milage trannies are the hydraulic type and I've got a cable actuated clutch. I'm wondering if anyone has ever attempted to remove the slave cylinder from a hydraulic-clutched tranny and install the cable stay bracket instead. I know going the other way (cable to hyd.) would be tough because the slave cyl. bolts into the top of the bell housing. I don't happen to have a hydraulic operated tranny to look at for reference so I'm hoping that someone can either answer the question for me or post some fairly detailed pics of the top of one for me.
Thanks,
Jay
P.S. I know the difference between a push type and pull type clutch setups. I'm referring to the push type hydraulic setups.
Speed Safely
Subaru, All We'll Drive
Black '92 LSl 270Kmi 5MT (W00t! for 1/4 million on 4/27/07)
Laguna Blue '94 L about 130Kmi (I think) for parts, in storage
previous: Green '92 LSl 253Kmi 5MT (sold to ron post moose adventure, sold to someone else)
previous: Maroon '92 LSl 130Kmi +- (sold to Ron, mashed by moose, crushed)
Black '89 XT6 5spd AWD (storage)
Old 05-26-2006, 08:42 PM
SVX10's Avatar
SVX10 SVX10 is offline
Fighting with electricity
If you can clarify what pics you want, I have a spare hydraulic type sitting in my garage right now.
Old 05-26-2006, 09:05 PM
yes you can. Just use the cable bracket and use the cable release fork. As far as I know this should be the only thing you need to change. You cannot use a pull type clutch trans found in WRX, turbo legacy, and STI vehicles. Might I suggest actually converting to a hydro setup for future compatability issues. Cable trannies may be cheap but eventually you may grow tired of swapping trannies, I know I did and finally jumped for a 6 speed
Old 05-27-2006, 09:00 AM
Still a member
Thanks Tom for the quick answer. I'm probably not going to change over the pedals etc, if it's this easy to convert a tranny from hyd. to cable. If I ever do a manual swap again I'll probably try to go with a pull type tranny from a WRX which will hopefully be more durable. I'll also have less to worry about when doing the swap, like sourcing a good clutch. The only thing I'll probably miss will be the 4.111 ratio diffs since the WRX uses the 3.545 rear.
Anyway, I digress. SVX10, I'm still interested in having those pics for reference. The area I'm looking for good pics of is from the top of the tranny, near the bell housing where the slave cylinder mounts back to about the middle of the top of the tranny. This would include a few of the case closure bolts and the clutch fork entry area.
Thanks again,
Jay
Speed Safely
Old 05-28-2006, 12:48 AM
SVX10's Avatar
allright...I'll get on that. Check back soon.
