Buzzzzzzzzzzzzzzz SHUT UP!
Ok im getting the 1900 RPM buzz from the secondary cat... is there any other solution then replacing it? can i hammer the h. e. double hockey stick out of it? or drill some holes? (yeah i know it probobly wouldnt work)
The buzz is probably caused by the exhaust shrouds vibrating. I know it's getting to be very annoying on my '92 Ebony.
I'm thinking about trying to remove mine, then I'll just have to stop parking on dry grass. Dan |
Well, their pourpose is to make it as annoying as possible to remove the exhaust. Do yourself a favor and remove all the heat sheilding , minus the one on the main cat.
Oh, and a secondary thing is to prevent any kind of grass or leaves from catching on fire. Because lets face it..after a long drive, EVERYONE parks on a large heap of leaves But seriously, if your planning on being under the car more than a year, youd be better off removing them.
R.I.P Cool Signature. You're gone but not forgotten. I mean, sure, I kindof don't remember some of the finer details..but I remember you were funny, and at one point you said spaghetti in Dutch....but definantly not forgotten |
i removed all the shildong on mine..... no probs
The buz maybe comin from here: If this is not the problem, id bash the crap out of the cat with a hammer, then id drill holes in it, then id go to en exaust palce and get it fixed or replaced
1992 Pearl / Black SVX removed intake silencer, k&N pannel filter, trans cooler, 94 JDM 4eat, Noltec front swaybar mounts, Motorsport D&S disks with EBC Greenstuff pads |
Internal
Some of them do buzz from the inside and it can be very annoying. A year or so ago there was a thread on here where a member cut it open and did a fix on it and then welded it closed.
Lee
SVXx2 92 SVX LS-L Silver 92 SVX LS-L Burgundy (structurally challenged with 2792 miles) 96 SVX LSi Red 92 SVX LS Pearl (Parts) 01 F150 4X4 Red (+6 with other members of the family) FREEDOM IS NOT FREE |
I think you guys are thinking of the primary muffler buzz, not the secondary cat.
Mike |
Use this diagram for proper terms:
Primary Muffler, aka "Stock Resonator"
FYI - no one should be seriously considering cutting open a catalitic convertor - lots of nasty heavy metal in there that has been know to cause cancer. You're better off just replacing them with high flow convertors now on the market.... -Bill
yep thats what i was thinking of
2-5 are going to be gone on my soon hopefully, then a turbo install
98 Impreza Wago-O-Doom & Datsun Roadsters |
Clarification
I should clarify my somewhat ambiguous post. I do not advocate cutting open the catalytic converter. I was actually referring to the resonator. The catalytic converter has rarely been a problematic noise maker. It is nearly always the resonator that developes the tinny sounding buzz and is the one that the member on here had a fix for opening it and welding in an interior piece and then closing it. Another option, of course is to simple cut out the resonator and replace with a straight piece of exhaust pipe.
Lee
the sound from my '92 got so bad I couldn't stand it... I took it to a muffler shop and they replaced my resonator with a generic "import resonator" worked well didn't change the sound or performance to my knowlede, and only cost about $85
yeah its my resanator thats buzzing.... im going to replace it as soon as i can find a welder
Thread Tools | |
Display Modes | |
