Old 04-15-2006, 11:34 AM
black beast black beast is offline
Back Road Blazer
Send a message via AIM to black beast
Replacing the plugs, help?
Where are the Spark Plugs on our car? I am having a really hard time finding them. Can someone point me in the right direction???
Bosch plat. +4 going in but can't find the plugs, and we don't have wires to follow...
Point me straight..
-Chris
'94 ebony pearl, with orange "silicone" hoses, painted beauty cover, Tom's Intake, Dayles Cold air intake; with HKS mega suction foam air filter, 3in header back exhaust, STI ground wires, euro front fascia, euro front grill, reactive 17in wheels, Nitto Invo's, Drilled and slotted rotors, stainless break lines, Koni strut inserts, Drop springs, 5MT, shotshifter, Clutchmasters clutch, ACT prolite flywheel, EL Glow gauges, The ECUTune stage 2. To Do: Cams, port and polish, etc.
Old 04-15-2006, 12:56 PM
Manarius's Avatar
Manarius Manarius is offline
They are under each coil. On each side of the engine there should be 3 plastic boxes. These are the coils. Remove them and you have access to the plugs.
-Jason
-Obi Wan Kenobi
Old 04-15-2006, 01:14 PM
Old Fogey
Just an additional note. Most folks are using the NGK's specified as OEM which are platinum tipped. The "advantages" of +2, +4 , adinfinitum have been well discussed here and on other Subie boards. Most agree the NGK's seem best suited to our motors/ignitions. Check How-To Documents/Engine/Sparkplug replacement. A word of caution to be careful with the coilpacks and wiring. They're EXPENSIVE to replace.
Glenn
Old 04-15-2006, 01:19 PM
svxcuseme's Avatar
svxcuseme svxcuseme is offline
5 speed 4 sure
Agreed...German plugs in a Japanese car...EEK! NGK is the way to go.
Spend a little time getting the right extensions for your ratchet, when removing the plugs. I use a Sears Gear Ratchet, Low profile 3/8" ratchet with 1" and 3" extensions. I never have to do all that remove the wheel / access hole crap.
Old 04-15-2006, 01:31 PM
bcpianoman bcpianoman is offline
Spark Plugs
There is a write-up in the How-To Documents section. I'll see if I can post the link.
http://www.subaru-svx.net/photos/files/How-To/14308.pdf
Old 04-15-2006, 10:12 PM
svxstarship svxstarship is offline
Installed Bosch +4's yesterday. Seems to run just fine. Used access hole in wheel well for drivers side back plug since I was swapping tires anyway, but after removing both rubber grommets to do the same on passenger side the access hole was not open clear through, but blocked by metal, weird.
1999 Audi A8. No more SVX's for now.
