Old 02-15-2006, 11:09 PM
It's Just Eric's Avatar
Missing in action
Of course it will sound a bit louder without that mesh. A big part of that may be that there is more surface area throught the mesh to absorb or disperse sound waves that there would be with straight pipes. Also consider it like this....If your in a rather large pipe and you yell...it will seem alot louder than if you were outside. This is because the soundwave is reflected and channeled back to you rather than being dispersed.
Anyway, back to the topic on hand...You can always try it. I recommend replacing the cats with a staight pipe rather than trying to shell out the cat..that way if it doesnt sound good, you can just weld the pre cats back on if it doesnt sound good.
R.I.P Cool Signature.
Old 02-16-2006, 07:04 AM
GreenMarine's Avatar
From POST-***** to LURKER
I can't just weld the primary's back in... They are shot... When my old engine was in there, just after the rebuild process wos complete, they got cooked... I mean to the point of GLOWING a bright orange... After that, and after my new engine, I have been getting a slight reduction in power (just barely) and more rattling... I don't have any heat shields, so that is eliminated... The only thing that I could think (because my girlfriend was riding behind me when I roasted the cats last summer and saw chunks of glowing "metal" coming out of the exhaust) is that my CATS are shot... That is why I am examining some possibilities... As far as daily driving the car, I don't... Infact, I haven't driven the SVX in over 2 weeks... It is now my toy/autocrosser/weekend car... My Diesel VW is my daily driver and will continue to be (with fuel prices the way thatt they are).... Anyway, I would like to go with some form of CAT in the exhaust. I just don't know any good brands out there... The idea about punching out the CATS was really just me being courious of what it would sound like... Also, anyone know the diameter of the pipe to and from the Primary CATS??
Thanks guys
Old 02-16-2006, 08:36 AM
mbtoloczko's Avatar
sans SVX
People seem to be having the most success with the Magnaflow 2-into-1 cats. The 2-into-1 design seems to cause less resonance than a y-pipe followed by an inline cat, and the 2-into-1 cat has a larger brick so it should cause the least amount of flow resistance.
I've got a brand new one that I can sell you for a great price. Its been sitting in my garage collecting dust.
Mychailo
Visit my locker
Old 02-16-2006, 08:55 AM
so mychailo do you suggest putting two resonators before the 2-1 cat to get rid of the resonance because it resonates really bad with just the 2-1. REally really bad and really really annoying. cause its right in the money rpms..Thanks for the help.
Old 02-16-2006, 09:38 AM
mbtoloczko's Avatar
sans SVX
Yes, it will help quite a bit. Another cheap trick would be to make one primary longer than the other. I haven't tried it, but this could be more effective than the resonators. It would change the exhaust sound of the car though. It would probably sound a little rougher.
Mychailo
Visit my locker
Old 02-18-2006, 10:23 PM
I don't need a 2-to-1 CAT... I have the three peice Stebro (just like you) and I'm not giving that up for anything. I am just looking for some good primary cats to replace the stockers... Metallic CATS prefferable..... Anything under $400 would be great....
Also, the exhaust diameter at the Primary CATS... Is it 1 7/8th inches??
Old 02-19-2006, 10:40 PM
WGJ WGJ is offline
mbtoloczko How Much...
for your 2 into 1 cat? I'm getting ready to do an early Chike 2 into 1 into 2 exhaust system. And in Calif. I'll be smogged again in Aug. And I don't have a problem with clean air. Do you take Paypal?
By the way...thanks for all of your technical info. Very helpful and much appreciated.
TRIED TO PM YOU BUT YOUR BOX IS FULL...
WGJ
Old 02-20-2006, 12:46 PM
WGJ WGJ is offline
Mbtoloczko
Tried To Pm You But Your Box Is Still Full...
Wgj
Old 02-20-2006, 12:54 PM
mbtoloczko's Avatar
sans SVX
Try again. I cleaned it out this morning.
Mychailo
Visit my locker
Old 02-20-2006, 04:56 PM
Doesen't anyone know of some good CATS that are High-flow and don't cost an arm and a leg???
Also, the measurement of the inlets and outlets of the primary CATS.... Anyone know that too???
Old 02-20-2006, 06:22 PM
mbtoloczko's Avatar
sans SVX
OEM primary cat inlet ID: 1.71"
OEM primary cat outlet ID: 1.61"
The Magnaflow ceramic substrate cats are fine. Metal substrate cats may flow better for a given brick size, but if you want better flow from a ceramic substrate cat, then get a cat with a bigger brick.
Mychailo
Visit my locker
Old 12-13-2006, 08:02 AM
Do ya think that a CAT with a diameter of 2" would work on our stock pipes?? Found the cats that I want and they come in 1.75" and 2" sizes... Just wondering which ones would be best to get... Thanks
Old 12-13-2006, 02:43 PM
I would use the 1.75" Chris. Closer to the original dia, if the dia/volume is too much bigger, it will cause the sonic wave to reflect at the cat, instead of further back in the system.
Old 12-14-2006, 07:51 AM
Good stuff, thanks harvey, that is exactly what I was looking for
Old 12-15-2006, 10:27 PM
rallyingrob's Avatar
rallyingrob rallyingrob is offline
i have nothing to ofeer except this......
mine has no "pre-cats" and still has the stock exhaust
the 2 pipes feed into one large cat then straight back to the muffler
it sounds fine, with no resonances that i've noticed...
(did cdn models only have the one cat? or is my exhaust not 100% stock?...it sure LOOKS fatory original....)
ps.........after we got the tranny in, we started 'er up to see if it would even run(purchased as a basket case).....NO exhaust system....straight outta the manifolds!!
and i'll +1 to the soundin MEEEEAN !!!!
bwuhahahaahahaaaaaaaaa!!!!
i'm too svxy for my car
rob
92 ebony 4.44's rock !!
