Old 01-11-2006, 02:58 PM
mhl0125 mhl0125 is offline
Send a message via AIM to mhl0125 Send a message via Yahoo to mhl0125
ABS Light/ECU
My ABS light came on. I checked the fuses under the dash and under the hood and all are OK. Should I replace the ABS ECU? If so, what is a fair price for a used one? Also, does this mean that my AWD isn't working?
Michael
1994 Barcelona Red SVX-LSI
Two-owner:169K
1995 Emerald Green SVX L AWD
#80 - Custom intake w/cone filter
99K with killer stereo system
2002 Acura MDX-Touring Edition w/navigation
2008 Toyota Prius
1987 Mercedes Benz 560SL
Old 01-11-2006, 03:13 PM
You can check the ABS ECU for trouble codes, to find the cause of the trouble. I think it is under the drivers seat? Woun't affect the AWD.
Old 01-11-2006, 04:11 PM
The procedure for checking and interpreting the codes is in the SVXipedia:
http://svx-iw.com
->SVXipedia
-->Checking Error Codes
--->How to Check ABS Trouble Codes
Old 01-12-2006, 02:03 PM
Thanks for the suggestions. I pulled out the front passenger seat, drove more than a minute at more than 19 mph, and the LED showed one blink. It wasn't short or long. How do I know if it is error code 1 or error code 10? Either one...what is my next step? Thanks.
Michael
Two-owner:169K
2008 Toyota Prius
Old 01-12-2006, 02:48 PM
It's code 1. Code 10 = 10 blinks. The ABS doesn't use short/long blinks.
Old 01-12-2006, 03:13 PM
That's funny. The SVXipedia you referred me to says it has long and short blinks. Long=10 and short=1 i.e., One long and six short = 16.
If it is Code 1, do I have to pull each wheel to check for the broken or shorted solenoid valve curcuit?
Michael
Two-owner:169K
2008 Toyota Prius
Old 01-12-2006, 03:27 PM
Oops, you're right. Can you submit feedback on the article to remind me to fix that please?
Old 01-12-2006, 03:34 PM
Feedback done. Thanks.
OK----Cananyone help me with Trouble Code 1?? What do I have to do next to locate the culprit. Are the broken or shorted solenoid valve circuits located in each wheel or are they under the hood with the ABS unit?
Michael
Two-owner:169K
2008 Toyota Prius
Old 01-12-2006, 05:01 PM
The solenoid valves are in the ABS unit under the hood. They turn off the line to the wheel that is locking up. You can check that the valve is operating or not, by checking at the connector that is behind the kick panel near the door. There are three connectors there. The long Black, two row, 20 pin one is the ABS. If you short terminal 2 to ground, which is the second from the left, top row, you should hear the solenoid click at the ABS unit under the hood.
You need to have the ign on to check, once you have checked one, you have to turn the ign off and on again to check again.
The other solenoids are;
Code 1, Left front wheel,.connector 2.
Code 2, RFW , connector, 11.
Code 3, RRW, connector, 12.
Code 4, LRW, connector, 3.
Top row of the connector plug is No.1 to No.9
Bottom row is No.10 to 20.
