Old 11-22-2005, 12:20 AM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
CounterAct Rust!
Has anybody heard of or tried the product called counteract? I just saw it on Two Guys Garage and what it is is 2 contact pads go on the car, one on one side of the back of the car and one on the opposite side of the front of the car. Then you hook up the control box and it sends electrical pulses through the body of the car through the contacts that make everything neutral so it don't rust. It sounds freakin' cool! I'll try to find out more info. on it and get back to you all.
Old 11-22-2005, 02:37 AM
I have something just like that on one of my cars. It does the same thing. I don't know the name brand, but I will find out and post it here. It is supposed to keep the car from rusting.
Old 11-22-2005, 10:53 AM
Sounds more like a hoax to me.
Does it charge your battery too?
Old 11-22-2005, 11:22 AM
dcarrb dcarrb is offline
Hard to imagine how an electriconic gadget could arrest oxidation and corrosion. The only thing that will prevent rust is protecting metal from the elements. And once it starts, the only way to stop it is removal.
dcb
Old 11-22-2005, 05:14 PM
kuoh kuoh is offline
Call the Mythbusters!
Electronic rust prevention article
KuoH
Old 11-22-2005, 05:20 PM
The last paragraph is the best advice:
Modern car manufacturers often do a process called zinc electroplating on the entire chassis of the car. So long as the zinc is complete, the car will not rust. Your best bet is to regularly clean out all the drain holes so that the water can't collect, scrape off any mud that has collected so that metal does not rust away underneath the mud, and remove the leaves and dirt. And of course, once you've washed the car, you should always take it for a drive so that any trapped water can slosh out.
Old 11-22-2005, 11:37 PM
Budfreak's Avatar
Banned
Here you go:http://www.counteractrust.com/
Check it out. you can see in the "counteract on tv section" about it being on two guys garage.
Old 11-22-2005, 11:41 PM
Budfreak's Avatar
Banned
WOW! that's pretty cool! I was just reading the counteract site and saw they did lab testing on it here in Akron and at Kent State University. Hometown tested. Now I'm buying one
Old 11-23-2005, 06:04 AM
Man, the copy on that site is nothing more than a raft of dense, techno-doublespeak nonsense. Familiar with the old saying, "If it sounds too good to be true, it probably is"? Save your money and forget about this foolishness.
dcb
Old 11-23-2005, 08:38 AM
They seem to imply that the device induces a static charge on the metal, hoping that the excess of "surface" electrons will prevent the iron from losing any. If you have access to a Van de Graaff generator and a few pieces of sheetmetal, you could probably experiement and find out for yourself if it works or not. If nothing else, it'll entertain the kids with long hair.
KuoH
Old 11-28-2005, 10:14 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Sounds like a recipe for "don't try this at home"....knowing me, I'd electrocute myself and the car would start and run me over.....Knightrider version 2005
1995 Subaru Svx L / AWD
Old 11-28-2005, 10:31 AM
Clydesvx Clydesvx is offline
Way over-the-hill Member
Can it also turn LEAD to GOLD.. If so I'm in!!!
'92 LSL TEAL 277,000 miles
Trans (on # 3) Engine (on # 2)
"NEW" VISORS
'03 Forester XS 214,000 miles
'05 Outback 3.0R
Old 11-29-2005, 03:20 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
The body will always be at the same potential as the negative pole of the battery - unless you disconnect all the earth straps.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 11-29-2005, 04:04 PM
Manarius's Avatar
Manarius Manarius is offline
Sorry..but electricity can't stop chemistry. Fe + H2O will always yield FeO2 + H2...
-Jason
-Obi Wan Kenobi
Old 11-30-2005, 05:48 AM
SVXer95 SVXer95 is offline
Word to Yo Motha
Why does galvanic protection seem too good to be true?
In the case of zinc electroplating, it most definitely works. This process has been used for many decades as a sacrificial protection layer. First, the zinc will corrode yielding white corrosion. Once all of the zinc is depleted, the steel will begin to corrode(iron oxide, red corrosion).
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
