Old 11-20-2005, 05:43 PM
Boxer6SVX's Avatar
Boxer6SVX Boxer6SVX is offline
Dont Drink and Drift
just bought an SVX and unhappy...
I have been thoroughly enjoying my SVX for the past few days now and tonight Im sitting at the drivethru at Burger King and i can hear a faint knocking... So here i am with an SVX thats probably going to need a new engine 2 days after buying it... sigh... im so screwed... no idea what this is going to set me back :-(
Old 11-20-2005, 05:47 PM
spinn360's Avatar
spinn360 spinn360 is offline
The fuel injectors tic a little bit on my car but that doesnt mean I will need a new engine. Can you isolate the sound? Hold a hose to an injector and listen to the other end while car is running see if thats the ticking if it is your fine.
1989 Subaru XT6 130k
1992 Subaru SVX 120k
1993 Ford Probe 30mpg 213k
1989 Subaru XT6 150k
All good and running
dwd1985 dwd1985 is offline
This might not be as big a deal as you think. What type of gas are you using? It needs to be premium gasoline, it says that on 2 different places on the car (instrument panel, inside fuel door) and in the owners manual. Make sure that you use the highest grade gasoline available, or else you will get engine knock. Read about it in your owners manual (if you got one when you bought it). Also, look up the procedure for pulling engine trouble codes, and see if you have any codes stored in the computer (like a bad knock sensor).
Old 11-20-2005, 05:49 PM
n00b on demand's Avatar
Relax. Just because you hear a "faint" knocking doesn't mean that your engine is going to go on the fritz and all hell is going to break loose. How does the car drive? Does it stall or do anything weird? Is the car acting completley normal despite the knocking noise? My engine also has a very faint knocking sometimes...mostly when its cold . Check the oil level as well.
Old 11-20-2005, 05:54 PM
Don't worry yet. These engines usually go 300,000 miles or more without any trouble unless they overheat. The lifters tick from time to time, but nothing to get worried about. I understand that you just got the car and are somewhat cautious about what will happen next. We ARE here to HELP YOU !!!! Let's take one step at a time and check out what the suggestions were before my post.
Old 11-20-2005, 05:56 PM
By the way, check out the local SVX membership at http://www.nwsvx.com and get registered (free) for lots of fun and get togethers. Welcome to the site.
Old 11-20-2005, 06:46 PM
all of my svx engines...had a couple ... have had a slight knock to them at idle... I dunno I figured it came with the teritorry. THe only reason I even notice is becuase I am meticulous about the mechanical shape my vehicles are in... cosmetic is yet another story
Old 11-20-2005, 07:01 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Another thing, depending on the mileage of the SVX you just purchased, it's good insurance to replace all six spark plugs and do an oil change. From there, plan on doing a radiator flush, replacing the fuel filter and drain and refill the transmission atf (do NOT have it power flushed!).
-Chike
2006 Steel Gray WRX TR (sold)
Old 11-20-2005, 07:09 PM
svxxx26's Avatar
svxxx26 svxxx26 is offline
Headed to Texas...
Same here. My SVX has had a "slight knock" since I bought it 10 years ago. Freaked me out at first too, but it comes and goes and never has gotten worse or affected performance.
Jerry
2005 Baja Turbo
2008 Ford Crown Victoria Police Interceptor
jnj7707@yahoo.com
Old 11-21-2005, 06:12 AM
dcarrb dcarrb is offline
My experience with five Subarus enforces these truths:
1. All leak oil.
2. All knock, tap, klunk, groan, whine and/or whistle "Dixie."
3. All will last beyond 200,000 miles unless routinely abused.
My SVX engine is the quietest of the lot, and she purrs like a contented kitten at idle, but listen closely with the hood up and you can hear a symphony of curious, muted noises. It's a Subaru.
dcb
Old 11-21-2005, 07:02 AM
red95svx
They all tick to some degree. The tick should be just barely audible when the engine is fully warmed and all the windows are up.
Old 11-21-2005, 10:14 AM
intelisevil's Avatar
<<<Alcyone
I've got to disagree with that . . .
My sticky lifter is loud as heck with a window opened even a little bit.
When my windows are all up I can't hear it due to SVXi superior use of sound deadening materials!!!
Dan
Pentiums - Melt in your PC, not in your hand!
Project - '92 Claret - Purchased May '06, 99,XXX Miles. Includes two bad engines and one bad tranny, cracked windshield, otherwise mostly complete.
His - '92 Ebony Pearl - Purchased Dec '05, 134,687 Miles. Parked, TC Seal(?) is leaking.Daily driver - 140,500 and climbing.
Hers - '92 Teal - Purchased Aug '05, 129,050 Miles. Daily driver - 160,000 and climbing.
PWR Radiator!
Problems:
Antenna doesn't work - Bought a 'new' one - Too cold to install . . . OK, it's warmer but I have other projects too!
Ticking from front of engine, passenger side - Stuck lifter?
Old 11-21-2005, 11:24 AM
chancuff
-Chike
Why not powerflush?
Old 11-21-2005, 11:34 AM
Originally Posted by chancuff
Why not powerflush?
Washes away alot of the friction material and in alot of cases after a power flush on a high mileage transmission alot of people have had tranny failures or slippage.
Old 11-21-2005, 12:08 PM
red95svx
I was describing a "normal" tick.
