Old 11-06-2005, 12:45 PM
dwd1985 dwd1985 is offline
Cleaning MAF/TPS
I am trying to clean my MAF and TPS, but I have run into 2 problems. First, how do I get the MAF off of the airbox? It seems to me like its all one piece, but I have seen pictures of them where the MAF is sitting alone by itself after someone has taken it off. Secondly, I am wondering about the scribe marks that I have to make on the TPS to get it back into the right position after I have cleaned it. Why would I have to scribe a mark at all? The TPS has 2 screws that screw into pre-threaded holes. Wouldnt that mean that all I had to do was line it up with the holes just like it was before, and then put the screws in?
Old 11-06-2005, 01:36 PM
it is removable from the box. you have to unscrew 4 bolts which are clearly seen on the upper part of the box where it meets the MAF.
Old 11-06-2005, 02:30 PM
billb billb is offline
After you remove the MAF, it's still in a cylindrical "can." That's as far apart as you can get it. You can stick a Qtip in to very gently clean it.
Yes, the TPS has two screws, but the screw holes in the TPS are actually slightly slotted. This allows you to slightly rotate the TPS to set it correctly. After you set it (position it) properly, you tighten the screws to lock it in place. If you take it off to clean it, you'll probably want to use a voltmeter to set it correctly rather than rely on your scribe marks.
Good luck
Bill
94 SVX LE 130,000mi
Old 11-07-2005, 12:25 PM
I wonder if it's possible to "misalign" the MAF so that it doesn't max out as easily?
Old 11-07-2005, 12:51 PM
thundering02's Avatar
Giong back to the beaters...
Wouldn't it still be flowing the same air? not sure that air travels say like water loweset point possible at least at 300 CFM.
89 240sx se Black~185k R.I.P.
85 Toyota pickup ~205k R.I.P.
Old 11-07-2005, 05:35 PM
I'm sure it would make a difference. It's just like hiding behind a wall when it's windy. It works off of temperature. If there's less moving air over the wire then it will read less.
Old 11-08-2005, 08:39 AM
Sorry I have the cone air filter(green) and air comes in from all sides of it(think tornado or something so no walls for me.
