Old 09-11-2005, 04:31 AM
The Molinator
Cat...cat...cat!
I guess we have three catalytic convertors in our SVX's. I already replaced the high-flow cat which was majorly trashed (possibly from head gasket failure produced water...?) and making my car to run very poor even after the head gasket replacement! The muffler-man was concerned about the front two (2) cats that are part of each side's exhaust manifold (which Y into the high-flow cat. I think I sense a slight strain noise (major when high-flow cat was clogged!) still upon acceleration! SOOOOOooooo.....Should I replace those two cats (about $175 apiece) to be safe...? If one or more is bad (or about to be), they could cause the high-flow cat to fail AGAIN! ......And the head gasket could be blown (or WORSE) with the resultant clogged exhaust! Please advise.. . . .
THANKS!
Jim
Old 09-11-2005, 05:53 AM
svxsvx
take a different approach
James,
I appreciate I dont know your laws as far as modifications go but if you have the need to replace something you also have the opportunity to improve something. The standard SVX exhaust set up (apart from the exhaust manifold) is a dog. Get yourself down to a performance based exhaust specialist and look to minimise as much of the original crap as you can (still complying with your laws). Off the line speed suffers a little but acceleration over the power band and the note makes it worth while.
Old 09-11-2005, 07:48 AM
thundering02's Avatar
Giong back to the beaters...
Unfortunatly for you being in California you have to have all three cats in order to even pass emisons inspection. Otherwise you have to get somebody with a little more knowledge on cat's to tell you otherwise.
89 240sx se Black~185k R.I.P.
85 Toyota pickup ~205k R.I.P.
Old 09-11-2005, 01:20 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Most replacement cats are rated to replace not only the main cat but also the pre-cats. If yours are so rated you could 'gut' the pre-cats with a steel rod and hammer then bolt the exhaust back up, leaving the original shells in place. As long as it blows good numbers and it appears to have the OE cats in place...
p.s. bad precats won't damage the main cat.
Old 09-12-2005, 06:49 PM
The Molinator
CATS galore!
Beav...A good idea!...BUT, noone will do it! They could lose their license.. .
So, I have to put 2 new front cats to have piece of mind.. . . or just hope for the best..and chance that it's OK..and that it will stay that way awhile! He said they (the fronts) are stainless inside (not like the regular other, incl. high-flow rear cats which are ceramic)? He will charge $180 apiece installed.
PLEASE SHARE ANY OTHER IDEAS you may have, guys.. . .
THANKS!
Jim
Old 09-13-2005, 09:57 AM
thumper_svx's Avatar
thumper_svx thumper_svx is offline
Either committed, or should be
Send a message via ICQ to thumper_svx Send a message via Yahoo to thumper_svx
Dunno if this would be legal in Californa, but I replaced my entire exhaust from the engine back to the rear muffler, and in doing so replaced the three cats with two cats from a 3.8L Mustang. MUCH cheaper than the Subaru parts... in fact I think the entire exhaust system cost me less than a single cat for the SVX.
She passed Missouri emissions without a problem after I'd made that change... and it freed up the power a little since it was slightly less restrictive than the stock exhaust (read; slightly bigger pipes).
