Old 08-19-2005, 10:56 AM
SVXgarcia SVXgarcia is offline
Send a message via AIM to SVXgarcia
Cleaning plastic on mock light and hedlights
I remember seeing something here regarding a how to on cleaning the plastic on the headlights and mock light. I tried lacker thinner but it leaves a white dull surface. any suggestions?
Old 08-19-2005, 11:50 AM
What I've found works great and takes very little time is to take some fine scratch remover (I used Eagle One brand) and rub it into the lights with your fingers then buff off with a towel of choice.
Old 08-19-2005, 12:33 PM
thundering02's Avatar
Giong back to the beaters...
Just to note A scotchbrite pad and some water do wonders until time for the scratch remover or simple buffing compound.
89 240sx se Black~185k R.I.P.
85 Toyota pickup ~205k R.I.P.
Old 08-19-2005, 12:34 PM
Dza's Avatar
Dza Dza is offline
#073 of 301
I used 600 grit sandpaper, then 1000 grit, then 1500. After that, I hit it with some Maquires plastic polish. They look goooood.
Results here: http://www.subaru-svx.net/forum/showthread.php?t=26544
Dan M.
Barcelona Red '93 AE #073 of 301, 168k miles.
Old 08-19-2005, 12:45 PM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Brasso
Before you use sandpaper, try some Brasso. If that does not get the scratches/yellow out use some real fine grit sandpaper and then the brasso. RainX after brasso.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 08-19-2005, 02:05 PM
ssnsltd's Avatar
ssnsltd ssnsltd is offline
That's gona leave a mark.
Bon Ami cleanser works well. I started using it after seeing a Shade Tree Mechanic show talk about it.
That will take off the yellowing, but imperfections in the lens from acid rain, chips ETC will still effect the beam pattern.
I used that on my 96’ and my brothers Florida Cars with great results. Use just enough water to make a paste out of it and polish the surface.
My 95’ lights were much worse so I used 2000 grit sand paper (wet sand) followed by Turtle wax (red) heavy duty rubbing compound, then 3M liquid polishing compound. That worked extremely well. When I used Liquid Glass over that they looked factory new. So good in fact now my 96’ lights now look like crap when the cars are side by side so I intend to do the same thing to them.
David
96LSi 102k Laguna Blue
95 LS-L AWD, Safety package, 140k Polo Green
the Chick Magnet:
91 Justy GL EFI 4x4 154k (new motor @120k)
90 Yamaha V-Max
82 Yamaha XJ650LJ Turbo
My Diver Propulsion vehicle:
88 Jeep Cherokee 160k
"U-sta-have"
88 XT6 AWD Pearl,
86 XT Lt Blue,
85 XT AWD/4x4 Turbo Space Blue
Old 08-22-2005, 01:47 PM
Here's what Eagle One fine scratch remover will do for you. Can you tell which headlight I cleaned?
Old 08-22-2005, 02:57 PM
Wow were do they sell Eagle Brand scratch remover? come on fellas let's see what your lenses look like.
Old 08-22-2005, 03:02 PM
I used 3m rubbing compuond ($10 for a bottle@walmart) and mine looked like that and after driving with the haze on the left for while (cleaned sort of) Man Does that make a difference
Old 08-22-2005, 06:21 PM
I don't think Eagle One offers the exact product I use (I got mine well over 3 years ago) but the closest I could find from them is this stuff:
REFERENCE LINK
Basically go to your favorite place for buying car detailing products and look for any kind of fine scratch remover and that should do the trick.
Old 08-25-2005, 07:17 AM
red95svx
I use Blue Magic Plastic/Plexiglass cleaner. Great stuff.
Old 08-25-2005, 10:35 AM
UberRoo's Avatar
UberRoo UberRoo is offline
SVX Appeal
http://www.subaru-svx.net/forum/showthread.php?t=27520
Look at the section where I buffed out my old lenses. Solvents will almost always make the problem worse.
UberLocker
