Old 08-11-2005, 06:35 PM
The Molinator
AT ...or not?
Should I plan to rebuild AT while performing head gasket service on engine (to be removed)....or just wait til tranny problems show up? I've heard in the past that our Nissan AT's like to need a rebuild @ about 120,000 miles...? My SVX has 111,000 miles! The only problem I've had with my AT is a slow (sloppy!) shift from 2nd to 3rd...BEFORE I installed a Smallcar.com Shift Kit!
THANKS for any help!
Jim
Old 08-11-2005, 07:31 PM
thundering02's Avatar
Giong back to the beaters...
I prefer the Idea of a manual swap over the cost of rebuilding the auto.
89 240sx se Black~185k R.I.P.
85 Toyota pickup ~205k R.I.P.
Old 08-12-2005, 02:13 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
AT rebuild is expensive and doesn't require the removal of the engine. You're not going to save anything by doing it now. Might as well wait until it does start giving problems.
If it aint broke don't fix it.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 08-12-2005, 02:27 AM
The Molinator
MANUAL vs AUTO
How much is a manual swap? Is it a clean result....Or does it entail "custom" alterations that appear homespun? How much more HP ....or zip?
Thanks! .....for your opinions!
P.S. Is there anything to doing an AT rebuild that could beef up.... or even improve performance of the AT?
Jim
Old 08-12-2005, 06:17 AM
dcarrb dcarrb is offline
I agree that you might as well leave the transmission alone if it's behaving. As to switching to a manual, it's one of those things on which you can spend very little or quite alot, and the result, both aesthetic and mechanical, would depend upon the skill of the person(s) doing the work.
As to "how much more HP?" Zero.
dcb
Old 08-12-2005, 06:41 AM
red95svx
If it ain't broke........don't fix it. My tranny has 165,000 and is doing fine. There are others with high mileage also. Unless you have money burning a hole in your pocket or you're planning a very long road trip I wouldn't spend any money on it right now. I personally won't touch my tranny until I lose a gear....or two
Old 08-13-2005, 05:50 PM
With a "sloppy shift 2nd to 3rd". I think you could do a band adjustment. The shift kit is just covering the problem.
Old 08-13-2005, 06:00 PM
freak customs freak customs is offline
Send a message via ICQ to freak customs Send a message via AIM to freak customs
you won't gain any hp from converting it, however most people love the feel of the svx as a manual. as far as "beefing" up the auto., i went with a rebuild kit from level 10 and it feels great. costwise it would be about the same to rebuild the auto as opposed to a manual swap so it's mostly up to the owner and whether or not you can find someone to do it (i couldn't )
Old 08-14-2005, 06:02 AM
The Molinator
REBUILD AT....OR SWAP to 5-Speed?
How much would this cost?
Jim
Old 08-14-2005, 08:11 AM
Click on How_To at the top of the page. As I remember someone said around $1,200 .
Old 08-17-2005, 11:45 AM
There is no exact cost for a 5 spd conversion. It depends on the cost of the parts and the cost of the labor. It cost me about USD$1800 for all the required parts from a 2002 WRX to do my conversion and we did all the work.
You can find older trannies for under $1000. Labor will probably be around $1000 if you can't do it yourself.
As for the feeling of driving a MT SVX it doesn't compare. I had a ride with our admin Chris in his 4eat SVX which he drag races and the launch doesn't even come close to that of my 5MT.
I took a couple other owners for a ride in my SVX and now they want to convert theirs as well
Old 08-17-2005, 08:21 PM
The Molinator
5 what?
OH... Great!
Now I have something else to lust after!
THANKS!
Jim
Old 08-17-2005, 11:56 PM
Yay I corrupted someone again
Old 08-18-2005, 10:57 AM
Oh sure...I do all the work and you take all the credit!
