Old 08-10-2005, 09:21 PM
SVXgarcia SVXgarcia is offline
Send a message via AIM to SVXgarcia
Location of Knock sensors
Im getting code 28 Knock sensor 2 (LH) Abnormal voltage in knock sensor monitor circuit. Where do I find it, where do I buy the part?
Old 08-10-2005, 10:31 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
You can see the passenger's side knock sensor if you look right between the power steering pump and the alternator (it's under the intake manifold). You'll have to remove the alternator to allow for easy access to it. There are pictures in my locker of when I replaced both knock sensors. ImmortalSuby also has some good pictures in his locker. Finally, I believe there is a "how to" write up in the "HOW-TO Documents" - see the link in the upper right hand corner of the site's home page.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 08-11-2005, 01:17 PM
red95svx
The SVX knock sensors are the same ones used on the early Legacys. They are readily available at any Subaru dealership or online at www.subaruparts.com
Old 08-11-2005, 02:52 PM
SVXRide's Avatar
Dave,
Wasn't there a TSB issued on the knock sensors in which Subaru stated that you should only use knock sensors that have a white connector (versus the earlier sensors that had a gray connector)?
-Bill
Old 08-12-2005, 06:19 AM
red95svx
Originally Posted by SVXRide
Dave,
-Bill
They all have white connectors now.
Old 08-12-2005, 09:27 AM
SVXRide's Avatar
I was thinking more along the lines of folks wanting to use "used" knock sensors...
-Bill
