Old 08-04-2005, 11:57 PM
scoobymal's Avatar
scoobymal scoobymal is offline
Smile Yellow Peril Back On The Road!! (cooler Pics)
I am quite pleased with myself,changed radiator,thermostat,water pump (modified) timing belt.I'm no mechanic just a gas fitter(methane) pics are of the UK spec/type oil cooler fed from the water pump.
US spec pump did not have water feed to oil cooler sandwich block,drilled and tapped,brass outlet fitted.149,000 miles what's going to go wrong next??
Mal.
Old 08-05-2005, 12:57 AM
94svxred 94svxred is offline
Well done!
Old 08-06-2005, 01:52 AM
mile-hi-bri mile-hi-bri is offline
Oil cooler
I'm curious.
Where does the water return to AFTER it goes thru the oil cooler sandwich?
Does it go back into the sytem via the rad hose or...
Inquiring mind need to know!
Thanks, milehibri - Brian
