View Poll Results: Do you use the PWR radiator's 5 pass trans cooler with an aftermarket trans cooler?
I use the PWR radiator AND a trans cooler 2 50.00%
I use the PWR radiator trans cooler only 2 50.00%
Voters: 4. You may not vote on this poll
Old 08-03-2005, 06:17 PM
immortal_suby's Avatar
Thread Killah
Originally Posted by Chiketkd
Hmmm...can't believe you have a PWR aluminum rad and bypass the internal cooler completely!
-Chike
I have 2 external coolers - one with a fan- I rarely get up to 180 unless I take a trip to the dragon or autocross or something like that (in which case 5 coolers probably wouldn't help)
I don't see a need to heat the tranny to over 190 every day. My 17 mile trip to work every day rarely heats the tranny up to 160.
I might run the PWR cooler this winter to help the warmup/ 4th gear shift though.
Locker Link
2015 BRZ Limited 6MT
Old 08-03-2005, 11:53 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Originally Posted by AFBeefcake
I installed the PWR in my car and remove my B&M cooler. Just using the PWR cooler works as good or better then the stock rad and a 16,000 GVW B&M cooler.
I got a temp gauge so I've seen before and after temps.
Cool. That's the kinda info I was looking for...
Plus, as I have 4.44 gears, the atf in my trans will be pumped around at a faster rate when driving compared to stock 3.55 gears...
-Chike
2006 Steel Gray WRX TR (sold)
