Old 08-01-2005, 11:19 PM
drivemusicnow's Avatar
Poor College Racer
bah! Knock sensor problem search....
Okay, So I got a code a while back for my knock sensor, bank 1, sensor 1. which equates to the drivers side, or back sensor failing. my car has over 100k on it so I figured that it was probably just the sensor. bought one from tomssvx, finally had some time to put it in today (which was really not hard at all... other than the 95 degree weather)
Put it in, and while i was working on it, i had the battery disconnected, put everything back together start the car... and NO CEL.... drive for 10 minutes.... CEL is back, have the code read, its the same one as before. bank one sensor one.....
I'm going to try and have the codes cleared (however if it wasn't on when i started the car... i think it was already "cleared"), however what else can i check? the sensor i took out looks good to tell you the truth, and its not like a knock sensor is a very complicated sensor... its just a microphone.
Greg
97 Red SVX LSi clean
96 Black SVX LSi beater
90 Red Eclipse GSX track ho
99 Ford F250 work horse
Old 08-02-2005, 08:27 AM
red95svx
Was the sensor used? Could be that it was bad. Faulty wiring to the sensor can throw a code also. I shouldn't even have to ask about premium gas, right?
Old 08-03-2005, 12:14 PM
Poor College Racer
no, premium gas has always been used... and that wouldn't throw a fault code for 4 months either
The knock sensor i took out looked fine, the one i put in was used, however it was fine on toms car so i'm going to assume its not the sensor... how do you get to the wiring? does anyone have the service manual list of things to check in order? Because that wiring is a ***** to get to, and if thats not it... i'd like to know what else it might be.
Greg
Old 08-03-2005, 03:49 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
What is peculiar is that the light came on for a knock sensor. First time I've heard of that, the code is usually stored but without turning the light on. Any other codes?
Old 08-03-2005, 04:39 PM
That happened to me (and started my thread about the electrical gremlin here: http://www.subaru-svx.net/forum/show...trical+gremlin
The CE light came on in my 96 and the OBDII reader at the Subaru dealer said it was Knock Sensor 1. They put a new one in, cleared the codes and the CE light was out for about a week. Its going back into another dealer to check it out. I hope I wasn't ripped off for a sensor I didn't need
Old 08-03-2005, 08:14 PM
Poor College Racer
Yeah, thats the only code its throwing... i'm confused out of my mind... can't think of what it could possibly be... unless its the wiring...
svxcess... please keep me informed!!! i also have an OBDII 96 so any new clues for me to check out would be extremely helpful
Greg
Old 08-04-2005, 09:55 AM
PaulSVX's Avatar
PaulSVX PaulSVX is offline
Some problem
I have simmilar problem to the one you described, when I start the car (not always) it sends a code 22 (Knock Sensor) and check engine light stays when idle, at higher rpm it goes away (strange). In my opinion the problem is somewhere else. Would it be that the sensor detects too many detonations and throws a code? "abnormal operation" doesn't necessarily mean a bad sensor.
Old 08-05-2005, 02:50 PM
Knock sensors will trigger a CE light. On the select monitor, a bad knock sensor 1 will throw a 22 code and the knock sensor 2 code will be a 28.
The SVX Master Tech at my dealership said there was a TSB issued in late 1995 for the 1992-1995 SVX for inoperative knock sensor issues. It can be found here: http://members.tripod.com/quick_svx/.../42748280.html
My CE problem turned out to be a disconnected vacuum hose at the pressure sensor (solenoid valve), located at the far left corner of the engine bay on the side of the left strut tower. It is a small black plastic piece with the PN 14774AA500 in white across the top. There is a small vacuum line which comes out of the rear, right by the horizontal, aluminum piping on the firewall.
We zip-tied in in place to make sure it wouldn't happen again.
He ran the codes and immediately knew what the problem was. Fixed in in less than 5 minutes. This is the second time in a row he come through with flying colors!!
Old 08-06-2005, 12:04 AM
Poor College Racer
Was this on your 96?? I'm confused, cause OBDII cars don't throw those codes, nor came in 95 or older cars... I'll look anyway... can't hurt.
Greg
Old 08-06-2005, 08:32 AM
Sorry, I was in error in posting those codes from the Subaru Select Monitor. I have a 1996 LSi with 88,000 miles; OBDII
The tech ran the codes and captured a freeze frame on the select monitor of all of the values for each component checked. The only code that showed up as abnormal (thus triggering the CE light) was P0106 (Pressure Sources Switching Solenoid Valve). For this item The FSM 96 supplement said check the vacuum hose.
All the other codes were normal. The code for knock sensor 1 is P0325. The code for knock sensor 2 is P0330.
The FSM says the procedure is the same to troubleshoot both sensors:
1. Check harness between knock sensor and ECM connector
2) Check knock sensor
3) Check input signal for ECM
(The 1996 FSM Supplement is a valuable book to have. It goes into a great amount of detail on the OBDII system, checking codes with the Select Monitor and how to remove and reinstall most of these components. The PN for this manual is MSA5T9605A)
Old 08-06-2005, 11:55 AM
I hope all works out for you. I do have another sensor if you need it. They were not faulty when I had them installed on my own vehicle.
Old 08-11-2005, 10:12 AM
PaulSVX's Avatar
Did you have code 22 or 28
Old 08-11-2005, 10:21 AM
The code was P0325 (knock sensor 1) on my 96 OBDII. On the earlier models, you would get a code 22 for the same faulty sensor.
