Old 07-31-2005, 08:30 PM
svxsubaru1's Avatar
Car wont start, fuel pump will not run?
Ok yesterday I was working on a starter problem, so i diconected my batter and dived into my sterring colom to get at the igntion switch. So any way my cousin and I had to drive it to pick some stuff up. So i put the conected the battery and cranked the car over with the ignition switch diconected from the key lock. The car turned over for about 5 secs with out any thing, so i turned it off then tried it again, the car fired in about 2 secs. Right then i just asumened that it was from the ecu being reset. Later tring to come home, i tried to start the car , nothing, it would just turn over. So my cousin wanted to see if he could hear the fuel pump running, when ever I turned the car the key on the fuel pump made a gurgle noise for about 3 secs then turned off. After tring to start it for about 10 mins, the car fired and I drove home. The car ran perfectley the whole way back, with what seemened to be the same amount of power as normal. Today I tried to start it just to see if it would run and it cranks but i cant even here the gurgle from the fuel pump any more. Any ideas. I have a stage 1 V4 ecutune ecu if this is a common problem.
Old 08-16-2005, 03:14 PM
Any updates?
Has the check engine light ever come on?
