Increasing compression on SVX engine.
Has anyone ever shaved the heads on a SVX engine to increase the compression ratio. I had a subaru 1400 engine 10 years back and shaved the heads it increased the power of the engine dramatically. The biggest problem I faced was keeping head gaskets on it. Have been tempted to shave the heads on the SVX. Given the bottom end strength of the motor it should have no problem taking the power. All suggestions greatly appricated or advise as to were I can find more infomation.
Tony |
were already at 10 to 1 compresion ratio and running premium can you affor better gas?
86 GMC Jimmy Blue and Silver- R.I.P. 87 Integra RS ~228k miles R.I.P. 92 SVX LS-L Perly ~186k R.I.P. 89 240sx se red ~165k miles Gone and unknown 89 240sx se Black~185k R.I.P. 85 Toyota pickup ~205k R.I.P. 85 BMW 325e ~ Gone and unknown 85 Ford Mustang getting engine swap now! 05 Colorado ~108k Daily Driver |
if you shave too much, you wont get the intake back on. You want increased CR, have custom pistons forged.
-- Chris Founder/Administrator SVX World Network ECU Tune (stage 1), PWR (prototype aluminum radiator) Amateur Radio - General Class - K7SVX #1 92 Teal LSl 246k (Dedicated SVX Race Car, now with 4.44 speed) #2 92 Teal LSl 125k (Retired, car rescued from a field of weeds) 2007 Impreza 2.5i Special Edition, Obsidian Black Pearl (Daily driver) 2001 Dodge Ram 2500 quad cab, Cummins turbo diesel 4x4 (race car & RV hauler) 1985 Honda VF500 Interceptor (fair weather fun commuter) Going on 11 years of NHRA bracket racing NHRA Div 6 Car/Driver # T654 (site being rebuilt, new name is www.teamsvxracing.com) 2000 1st Place Club Challenge Series 2002 3rd Place Season Track Champion, Import Racing (Firebird Raceway) 2003 4th Place Season Track Champion, Import Racing (Firebird Raceway) 2003 1st Place NW Regional Import Shootout (July 5th) 2004 1st Place Club Challenge #1 (Firebird Raceway) 2004 1st Place NHRA "King of the Track" race 2004 NHRA Gold Cup 2nd place season win 2004 Import/Sport Compact 3rd place season win 2004 Division 6 Summit/ET NHRA Race of Champions finalist competitor (Mission, BC) 2007 1st Place Import Survival #3 2007 1st Place Track Champion Import Summer Jam (Wild Street Class) 2007 1st Place Import Survival #5 2008 Club season 1st place win, Club Champion 2008 2nd Place Season Import Final. 2008 Division 6 Summit/ET NHRA Import Finals (Woodburn, Or) 2009 2nd Place Import Summer Jam (Wild Street Class) 2010 1st Place Club race #2 - 1st place Sport Compact race #1 & #2 |
The new Audi A8 is supposed to have a 12.5:1 direct injection gasoline engine. It cranks 256 HP from 3.1 liters. The V10 in BMW's new M5 runs a 12:1 compression ratio. (I think it's uses BMW Valvetronic technology.) Those both approach the lower limits of diesel engines. What's astonishing is that Porsche's new red rocketships have supposedly set a record for the highest compression ratio on a mass production engine. I can't remember what it was, but I think it was in the 13's. Yikes!
Of course, you still have to deal with octane. I'm pretty sure all those engines have some pretty sophisticated engine management systems to keep the monster alive. I would think you might be able to get 11:1 out of the EG33, but I'm not sure how well the ECU would adapt. I wouldn't be surprised if some of the experimental aircraft guys have tweaked the compression. Most aircraft engines are large displacement, slow turning, air-cooled motors. Since car motors are a rather different design, many experimental aircraft use a reduction drive system to enable the use of the upper RPM range. If they're doing that, then it makes sense to toy around with compression - especially at altitude. |
Thanks for that, on my old 1400 I cut the intake manfold and re welded it. Some how I need to be able to do the maths on how much I need to take off. The million dollar question is how much extra power you can get from doing the job. We can get engines second hand from Japan cheap in Aus so I am keen to have a play. These cars are tough, the older one I have has done around 150,000 K on dirt in the out back of Australia. I need a hobby so getting a third SVX to play with could be fun. Wife won't let me touch hers, give how good it is I agree.
Tony |
I did the calc's and if my maths is right then the bore is a constant so I only need to use the numbers for the stroke. I have had 5 goes at working this out different ways but I think the answer is at 11:1 shave 0.833mm off for 12:1 shave 1.45mm off. If I am right I don't think this will affect much of the manfolding issues. Given the numbers its worth a try. Now all I have to work out is if I do it what extra power I will get.
There is a bit of a story to this my grandfather had a 1398 vauxhall that he took the Australian land speed record with on 9th May 1925. My father tells the story that they did the first run and didn't break the record so they took the head off the car and used brown paper as the head gasket then went back and took the record. Based on that he must have got more power from some where. Tony |
I've heard of people having several "head shims" made in different thickness’. The head and often the block are milled down quite a bit. Depending on whatever suits their current mood, a shim will be selected and placed between two head gaskets. It's useful for testing different engine setups, but a lot of screwing around.
Saab has a neat variable compression engine that they've been tinkering around with for the last few years. It physically moves the crankshaft closer or further from the head to vary the ratio from 8:1 to 14:1. The motor is 1.59 liters and can produce 225 HP and 224 lb-ft of torque. That's 150 HP per liter! It can do that because it has a supercharger that pumps out 40 PSI when needed. I think the purpose of this experiment is to crank out big ponies and still get great economy by using the high compression ratios. Turbochargers are still probably a superior system, but lack the novelty. These can be fun to play with: http://www.bgsoflex.com/crchange.html http://www.wallaceracing.com/calc-crchg.php ...If only we were starting with a reeeally low compression ratio. |
I think Paeco sells some thin copper head gaskets for the EG33 (I've seen the stock ones off the car and they're pretty thick). Not sure how much they're supposed to raise compression by, but that could be another avenue to explore... -Chike
-Chike
"Wise men talk because they have something to say; fools, because they have to say something." - Plato 2013 Cosmic Blue 5spd Evo X GSR 2006 Galaxy Gray 6MT RX-8 (sold) 2006 Steel Gray WRX TR (sold) 1996 Brilliant Red SVX L (sold) Last edited by Chiketkd; 08-03-2005 at 11:47 PM. |
Thread Tools | |
Display Modes | |
