Old 07-28-2005, 01:14 PM
svxsubaru1's Avatar
What spring rate do you recomend for GC springs?
Ive decied to go with the koni GC rought and iam wondering, what spring rate do you recomend with GC springs. Ive read that 380F, 325R is spose to be one of the better setups. Remeber that this car is going to be a dailey driver.
Old 07-28-2005, 01:24 PM
That's the rates I'm using. The ride can be changed just by adjusting the front struts. That makes a big difference. It's quite acceptable for a daily driver.
Old 07-28-2005, 01:26 PM
svxsubaru1's Avatar
Thanks alot iam ordering them right now.
Old 07-28-2005, 01:37 PM
svxsubaru1's Avatar
There ordered and on there way, 380F, and 315R, they couldent get 325R for some reason.
Where is the cheapest place to buy koni inserts?
Old 07-28-2005, 01:43 PM
www.classicgarage.com
REFERENCE LINK
Old 07-28-2005, 02:32 PM
svxsubaru1's Avatar
Thanks again i just purchased some konis.
Old 07-28-2005, 03:35 PM
Weebitob Weebitob is offline
The Kind of Casual SVXer
Send a message via AIM to Weebitob
"Excluding those originally equipped with electronic suspension."
There were SVXs equipped with that? I thought the Subaru XT only had something of that sort. And if some SVXs did, how exactly did it work?
Old 07-28-2005, 09:34 PM
i guess I don't have it....
Old 07-29-2005, 07:22 AM
ssnsltd's Avatar
ssnsltd ssnsltd is offline
That's gona leave a mark.
I thought they were talking about the XT6 and some of the other Subarus that had the air suspensions.
Then I found this Thread so I guess a few SVX's did have an electronic suspension and steering system.
David
96LSi 102k Laguna Blue
95 LS-L AWD, Safety package, 140k Polo Green
the Chick Magnet:
91 Justy GL EFI 4x4 154k (new motor @120k)
90 Yamaha V-Max
82 Yamaha XJ650LJ Turbo
My Diver Propulsion vehicle:
88 Jeep Cherokee 160k
"U-sta-have"
88 XT6 AWD Pearl,
86 XT Lt Blue,
85 XT AWD/4x4 Turbo Space Blue
Old 07-29-2005, 02:30 PM
mbtoloczko's Avatar
sans SVX
They are referring to the SVX with 4-wheel steering.
Mychailo
Visit my locker
Old 07-30-2005, 01:16 AM
Now I know all SVXi have what has been called passive 4ws. Will the addition of the koni/GC nix that or just improve on it??
Old 07-30-2005, 06:35 PM
svxsubaru1's Avatar
Well if its passive then its probley built into the rear suspension, by having the rear lateral link not perpandicular to the transverse links which will cause the tire to toe in and out during travel, kind of like bump steer. So if you reduce the travel of the suspension less movement toe wise should happen so i guess it does take away from it.
Old 07-31-2005, 01:09 AM
1320boy's Avatar
1320boy 1320boy is offline
Team ROUND 1
Send a message via Yahoo to 1320boy
How much did those run you???
Old 07-31-2005, 10:38 AM
they are $660 from classic garage. If you call and talk to Ann she can get you free shipping for being a network member
Old 07-31-2005, 01:31 PM
KCROGUEDOG
free shipping i wish i would of known
