Old 06-30-2005, 01:36 PM
ilsegretosvx
05 STi hubs on a SVX
Has anyone tried this yet? Im seriously thinking about it. It would mean much more options brake and suspension wise. Im pulling a svx hub off this weekend and ordering a STi on Tues to see how diff they are and if it would work.
Old 06-30-2005, 04:47 PM
mbtoloczko's Avatar
sans SVX
I'd be astounded if the '05 STi hubs were a direct fit onto an SVX, but I'd be ecstatic if the STi hubs do fit.
Mychailo
Visit my locker
Old 06-30-2005, 04:51 PM
ilsegretosvx
Im thinking the bearing are the same, and so are the bolt patern, so why not give a try?
Old 06-30-2005, 07:38 PM
Subafreak's Avatar
Superbeast
I heard that they were exactly the same from one person, but I stuck my head under an 05 and the ball joint on the STI still bolts through the control arm like every other Subaru (sans SVX) so it is definitly not an SVX spindal. It maybe an SVX bearing and hub though, and the brakes and struts still might work.
Old 06-30-2005, 07:44 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Isn't the sway bar gonna be an issue. I thought it mounted differently on the Impreza based gentry?
Old 06-30-2005, 07:54 PM
...but I stuck my head under an 05 and the ball joint on the STI still bolts through the control arm like every other Subaru (sans SVX) so it is definitly not an SVX spindal...
So the STi Ball joint wouldn't fit onto the SVX contol arm...
Would the SVX Ball Joint fit into the STi Spindal???
Old 06-30-2005, 08:04 PM
Subafreak's Avatar
Superbeast
Yeah, there would be a problem with the sway bar mounting if you were to use the STI struts. (no sway bar mount on the strut body)
Old 06-30-2005, 08:08 PM
Subafreak's Avatar
Superbeast
No, the SVX ball joint mounts to the control arm and the tapered stud bolts in to the spindal, the STI ball joint mounts to the spindal and the tapered studs bolts to the control are. compleatly differend design.
Old 07-01-2005, 12:05 PM
ilsegretosvx
What about filing down the area that the strut fits over the knuckle so a WRX or legacy strut would fit?
Old 07-02-2005, 08:21 AM
Subafreak's Avatar
Superbeast
Well if the bolt spread is the same then yes, you could probly mill down the splindal to work with a WRX strut.
