Old 05-04-2005, 09:46 PM
THAWA
Just checked the 99 and 00 legacy FSM's, and the 02 and 04 impreza FSM. You're right, it is 43.5 psi.
Old 05-04-2005, 09:48 PM
svxsubaru1's Avatar
Originally Posted by svxfiles
I believe, the new gen, 2000 and up use aproximately 43.5 psi (it varies between stick shift, and automatic) fuel pressure regulators.
That is why I bought and installed one YEARS ago, as have several other members.
I have since switched to an adjustable fuel pressure regulator, usually set at 44 psi, (when normally aspirated).
I have run from 28 psi at idle to 80 psi under boost at 5500 rpm
Way too low, and way, way, way too high!
BTW, My findings are, that for a NA engine, right around 44 gives the best driveability.
So would i be able to use a FPR from a 2000 year Subie or newer? Would any one post some links with cheap good turbos that will meet my needs, I am having a hard time finding some, except on ebay, and most of those are I think are only oiled cooled.
Old 05-04-2005, 10:22 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Thumbs up
I recently installed a brand new '01 2.5L Impreza fpr rated at 43.5 psi. Since the install, I've noticed that my car feels stronger lower down in the rpm band (00rpms)...
-Chike
2006 Steel Gray WRX TR (sold)
Old 05-05-2005, 12:30 AM
Wreckless
Call me stupid but 370cc injectors sound almost like stock. And if not stock, they sound too small for what you're looking at. Get some side-feed sti injectors. They'll be cheaper and flow from 480-550 depending on which version/who you talk to.
APS is awesome!
370's are not ideal but with 6 of them gives us around 390-400 crankhp safely, with the AIC as well fuel will not be an issue for what we can do on the stock bottom end, particularly if we use race fuel. Plus, they are cheap and readily available. SVXtasy is also worried about tweaking the factory timing maps too much via adjusting the fuel signal with the Emanage too much, and changing going for a 38% increase will be much easier to compensate for than a 100% increase.
Particularly with the high compression of the stock motor he's worried about part throttle timing advance getting out of hand once he starts pulling fuel to compensate for larger injectors, so going too big can be a real problem. If the needs presents itself and the tuning on the 370's goes well I'm sure 555's will be in the future.
Old 05-05-2005, 07:37 AM
Hmm, interesting. Why does it matter if it's a manual or an automatic? How much does it vary? Just to be clear, when I said new gen I meant anything based on the Legacy line.
When I ordered mine, the sticks had a slightly higher pressure, it was something like 45.5 for the stick, and 43.5 for the automatic.
I got the pressures strait out of the factory service manuals when I worked at the Subaru dealership, now that I've moved on to an independant dealership, I have no easy access to those books.
The increase was with the 2000s and up as I remember.
Note, I do not believe that they list the sticks and autos differently now.
Old 05-05-2005, 10:49 AM
svxsubaru1's Avatar
Is any one sure that STi fuel injectors will bolt in to the SVX fuel rail? Or will there need to be some costome work done to it? Becasue STi injectors are definatley cheaper than than the nismo 555s.
Old 05-05-2005, 11:34 AM
svxsubaru1's Avatar
What about a VF34, or 22 or something?
Old 05-05-2005, 12:20 PM
I have some pictures in my locker;
http://www.subaru-svx.net/photos/fil...iles/25145.jpg
And the WRX style will not bolt in.
Old 05-05-2005, 01:53 PM
THAWA
Those yellow tops aren't WRX injectors, at least they aren't 02-05 WRX injectors. 02-05 WRX injectors are top feed, those are side feed. They may be Older WRX injectors, but more than likely they're an older version STi Injectors. They look almost identical to these: http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
The SVX injectors look almost identical to 92-94 NA Legacy Injectors. Infact, I do believe they are the same. There are multiple people using STi, or SR20DET injectors in 92-94 NA Legacy Rails. So since the injectors are the same, then yes you can use new STi or SR20DET injectors. Also to note, there are a couple different types of sidefeed injectors as seen in svxfiles' pictures. You want the kind the outside injectors are, not the middle one. I believe that's 95-96 300zx, all SR20DET engines, Q45, Version 5-6 STi, USDM STi, 05 Leg GT/ Out XT, 04-05 Forester/Baja. But don't quote me on that.
Old 05-05-2005, 02:12 PM
svxsubaru1's Avatar
I have also heard that the 2j22 NA injectors are the same as ours. Are some STi 550 CC injectors even availble for purchase?
Old 05-05-2005, 02:54 PM
In the course of my supercharger project, I was buying lots of stuff off of E-bay, and you don't all ways get what you pay for.
That's why they have a question mark after the WRX, and 300ZX labels.
Old 05-05-2005, 02:57 PM
svxsubaru1's Avatar
I was over at the legacy board, and it looks like the new 05 forester tubro, STi, legacyu turbo all use 550 Sti injectors that will bolt into the existing fuel rail on a NA legacy.
I know eabay is a horible place to buy some things, but some are aculey OK, thats where i found my SVX after all.
Old 05-07-2005, 12:39 PM
svxsubaru1's Avatar
I checked out the part numbers between a 93 legacy NA, and 92 subaru SVX and the fuel injectors are the same. So if the information from the legacy form is good, which it really seems to be, we can bolt in the newer, i gues 2004 plus subaru 550 fuel injectors with out any problems.
Old 05-07-2005, 01:27 PM
svxsubaru1's Avatar
SVXtasy do you think that your t3/to4e would be support the HP that i want?
What about this tubro? How much do you think it would cost to rebuild?
http://forums.nasioc.com/forums/showthread.php?t=765950
