Thread Tools | Display Modes |
I am always willing to help if you would like contact me directly sam@svxtasy.com. I am going to be using eManage to control the injectors. As well as do a bit of timing control. People in the 2.5rs community have had excellent success with the eManage and you can’t go wrong with a 600$ (you can find it for much less sometimes) management system. The problem is going to be getting the right settings for the SVX. But I think I can figure it out. The 370cc will not do much HP but with the additional injectors it will do just fine for my 10:1 compression needs.
www.svxtasy.com |
-Chike
I would highly recommend this over the CT-26 because the CT-26 is absolute junk. I've blown about 3 of them personally. The design isn't just old and crappy it is also bulky for its power output and because of the bit of help I've given SVXtasy on his setup I know first hand what a PITA space is in the SVX bay. The CT-26 also uses unique flanges that will not be portable to another (real) turbo and be a ***** to find to begin with. There's a few bolt ons with CT-native flanges available for the 7M-GTE Supras like mine such as the SP61GT but I just don't see a point in spending twice as much for a turbo upgrade than you'd spend on a typical T3/T4 hybrid that could be bought from just about anywhere and be available to support almost any power level you could want. Hope that helps. -Jeff Edit: My Avatar is a CT-26 that failed on me at about 15 psi. The shaft snapped at the compressor and the compressor destroyed itself on the compressor housing and then the open cartridge dumped pressurized oil into my intake piping and intercooler. Yay Toyota. Edit again: I just noticed your desired power output is 350-400hp. You will be hard pressed to find any stock turbo that would support that kind of power, and even MK3 Supras with upgraded CT-26's that cost upwards of $600+ core exchange typically struggle to break past 350rwhp. For 400hp on an SVX, You'll need at least a 50 trim. Count on spending at least $750 for a decent turbo, masterpower and ssautotrash/blown mountain on Ebay are NOT good turbos. Last edited by Wreckless; 05-03-2005 at 07:47 PM. |
Thanks for the post jeff. That is supra-jeff he is the sh!t
EDIT: He just put down 377 to the wheels very nice for what he has to work with.
www.svxtasy.com Last edited by SVXtasy; 05-03-2005 at 07:47 PM. |
Ill start looking for a t3 i gues instead of a ct26. Hey is your avatar a blown ct26 by chance? Thanks alot for the post.
Edit: Iam a bad speller Last edited by svxsubaru1; 05-03-2005 at 08:05 PM. |
I would like to add that i would like 350-400 hp on pump 91 octane crap. Any specific turbo that you would recomend? Tasy, or Wreckless.
P.S. Wreckless, one reason that I want to do this is one of my freinds has a MK3 subapra with a 2jze swaped into it, and i need to be able to at least not get ditched by him. At least when he desides to get off his ass and replace #6 piston with a hole in it. Last edited by svxsubaru1; 05-03-2005 at 08:03 PM. |
I'm assuming you mean a MK3 Supra with a 2JZ-GTE from an Aristo or MK4 Supra.
If that's the case, he's barely breaking a sweat to make 400whp, and that's easily done for him on 91 octane with only an exhaust, upped boost, and a decent intercooler even if he has the less desirable JDM motor with smaller injectors, turbos and cams. You will spend a veritable assload of money to catch that, small budget won't cut the cheese here as much as I'd love to see an EG33 screaming its way past MK4's. 400awhp in an SVX with 91 octane would be best done on at least a 61mm, I'd personally go with at least a 4in inlet T66 and get a P-trim turbine with a .68 exhaust side. This will require an external wastegate and significant fortification to the SVX's drivetrain & a pretty serious fuel system, as well as an intercooler much larger than SVXtasy's for optimal performance. If I was going balls out on a SVX I'd get a TEC III and skip dorking around with the stock ECU, pending how well SVXtasy gets the Emanage to behave with the stock ECU. TEC or Emanage, you'll be spending big big money. If you want to beat him on a budget I would recommend a built 4EAT with a tranny cooler & stall, 4.11's and Nitrous. Then spray on a window switch and race him in the 1/8th mile only, and give him sh!t about his crappy 60ft times and spank just about anything that isn't tubbed & on slicks across an intersection. Spend the extra money on nice wheels and a killer system and have just a nice ass car. Just my (verbose) 2 psi |
What about the dual turbine turbo? This is just something I decided to through in but could be a good option, just go to here, with an extreme example here, and look under the description of the Garret GT-Midframe towards the bottom, which are the models GT30-45, even though the lowest end GT model on that website would cost you $1,984.31 USD (and thats not including shipping). So perhaps you would have better luck finding it in other places, but since it is a large brand like Garret you probably won't find one for much lower, perhaps some of you know another brand that offer an alike turbocharger?
Also even with my limited knoledge of the exact workings of an automobile, may I be so bold as to say also these forced induction applications won't be too worth if you don't have a differential that can transfer every last bit of hp and torque to the wheels? Sorry, I couldn't help but peddle my own topic, but it is still a valid point. Last edited by Weebitob; 05-03-2005 at 08:42 PM. |
In any differential design there will be lost HP and the biggest job they have is staying in one piece and making both wheels transfer power instead of just one (in the case of a limited slip diff or spool) and doing it quietly. You can make stronger and more efficent differentials but they are noisy as hell and I'll take the extra few HP lost for a quieter gear profile.
The SVX diffs looked pretty damned beefy the last time I was under SVXtasy's car, the problem with the drivetrain is going to be making a transmission * center diff stay in one piece, as hard launches in heavy AWD cars kill trannies like no other. Adding sticky tires like drag radials or slicks only make it worse. The Garrett GT designs are excellent turbos, I've thought about a GT4088 for my own Supra. Garrett recently upped their prices across the board and while they are very nice turbos I personally believe the noticeable but bearable difference in lag (a couple hundred RPM at most) wouldn't be worth $1000+ to me. A T66 as I described would cost in around $900-1100 depending on the source, the turbine, turbine housing style, coatings, etc. A full dual ball bearing one would still undercut a comparable GT by several hundred dollars. |
I guess you made a very valid point about differentials I did not know, thanks.
While looking up dual ball bearing I came across this company that specializes in manufactures turbochargers for the WRX, and now STi. An ideal one would probably be the SR55, but they seem to be about a smidge cheaper than the Garret equivalent. Btw, there is also this supposedly specially engineered T3, not to mention Turbonetics. I am just wondering how this the custome T3 and Turbonetics turbochargers may compare to the others including the ones I mentioned before? However, there are probably better deals out there if you look hard enough. Last edited by Weebitob; 05-04-2005 at 12:46 AM. |
Call me stupid but 370cc injectors sound almost like stock. And if not stock, they sound too small for what you're looking at. Get some side-feed sti injectors. They'll be cheaper and flow from 480-550 depending on which version/who you talk to.
APS is awesome! |
Whats the cheapest, relible turbo that would be able to pump enough air for 400HP with out being over worked, and maybe still have a little left in it for the future, maybe 450hp max. Last edited by svxsubaru1; 05-04-2005 at 12:23 AM. |
#28
You don’t need to put 1500$ in to a turbo. Spend 600-700$ on a 60-1 or 57 trim t3. No eBay turbo!! I got fleeced by a turbo got on eBay!!
www.svxtasy.com |
#29
Also i dont need to win in a race against the 2jze, i totaley aggre that would cost me way to much, and since my friend has the ability to spend like 20 to 1 on me it would be impossible if he treid at all. All i want is to not get destroyed by him in a stright line. Then i can take him in the twisties. Last edited by svxsubaru1; 05-04-2005 at 12:39 AM. |
#30
Well if SR20DET injectors fit in the SVX fuel rail, then sidefed STi injectors will fit in the SVX fuel rail. You can get sidefed STi injectors for like 200-300 for 4.
Also note that Nismo injectors are rated at 43.5 psi of fuel pressure. So using them with the stock fpr, which is set to 36.3 psi, would make the 555cc/min injectors flow around 463cc/min. Last edited by THAWA; 05-04-2005 at 12:46 AM. |
Thread Tools | |
Display Modes | |
